  2. I was very favorably impressed by the Midland Ghost antenna. If I didn't need one with multi-band capability, I'd still be using it.
  3. Hello All, I just recently received my call sign, (WSJE500), and my two new Boafeng G11S radios should hopefully arrive today, or maybe tomorrow. I have zero experience with GMRS. The catalyst for embarking on this endeavour, was a hunting trip that I take annually. Cell phones do not work in that area, and my cheap FRS radios, sound like I'm talking to a deranged popcorn popper. In addition, I find this subject interesting. I understand that the G11S isn't waterproof, but I very rarely hunt in inclement weather and always carry a good supply of ziplock bags. I know it is only 3W, but they were only $40. Anyway, we will see where this takes me. It'll be me and my two adult sons, all on the same side of a ridge. The only available repeater is 15 miles away on the opposite side on an adjacent ridge. We will be down in the hollow. I have very low hopes of ever being able to hit that repeater. I will be ordering two additional radios, four total. These additional two will also be G11S as long as I am happy with the first two. This decision in based on the simplicity of the radios and the lack of experience that anyone in this party had with radios. One quick question: If I am using one of the FRS channels, do I really need to announce my call sign every 15 minutes? It appears that channels 1-7 are all FRS/GMRS and 5-watt, of which I only have 3 watts available. WSJE500 in Manchester, Tennessee - Out. :)
  4. Have you tried shouting your call-sign on the repeater and seeing if anyone else can hear you? With both radios side by side like you describe, you're de-sensing the receiving radio while you're transmitting to the repeater so it won't 'hear' much of anything until you come off the button. Try talking, see if you get anywhere. Or have someone hold the other radio some distance away and see if they can hear you.
  5. Today
  6. I wrote the CPS for the BF-F8HP Pro and co-manage firmware development, as well as dabbling in manuals and marketing. The BF-F8HP Pro has user-upgradable firmware and the upgrade tool is integrated into the CPS. There have been 3 public releases of firmware (V29, V33 and V44) and there will likely be ongoing future releases. The radio you bought on the first day it was available (October 1, 2024), today, and at some indefinite point in the future will all be able to run the latest firmware. Feedback from users here, on Facebook and elsewhere gets evaluated and often results in new features and/or bug fixes. I don't know anything about the UV-28 Plus - I stopped collecting random Baofeng models once I got involved in the BF-F8HP Pro project. BTW, you can get 20% off the BF-F8HP Pro (radio only, not accessories or other models) on the https://baofengtech.com web site (not Amazon) by using coupon code "CPS" at checkout. * It should be obvious that I'm involved with the BF-F8HP Pro project, but here's a disclaimer anyway.
  7. The Wal-Mart I shop at uses 2 different models of Motorola MURS h-t's, they used to use one or two Ritron MURS base stations, but with the stock antennas on both the Motorolas & the Ritron, no roof antenna there Next time I go, I'll have to see how far away I can copy them
  8. A repeater may not always give you the ID back. It's usually on a timer (15 min) and will only ID after that time has expired. If you are receiving a signal back pressing the PTT you are hitting the repeater.
  9. They definitely gave you the wrong information. They gave you the offset for VHF repeaters which is 0.600 MHz. And that is why you came up with 463.300 MHz The correct offset for GMRS is 5.000 MHz which will give you the correct offset frequency of 467.700 MHz. GMRS repeater channels always use a positive offset of 5 MHz. Your radio will transmit on 467.700 and receive on 462.700. The repeater will transmit on 462.700 and receive on 467.700
  10. Well, i got the so called unlocked UV5R today.. It's not a UV5R but rather a BFH6.. I contacted the seller and he said i requested a unlocked radio to 520 and that is the model he can ship for my request. $29 bucks.. I aint gonna complain. it is unlocked and i think it's a tri band.. No manual either. I never heard of this model but it looks decent..
  11. The GMR2+ is a GMRS radio so you dont have to worry about, or even think about offsets - you just select the correct "Repeater Channel" and enter the TX tone and (optionally) the RX tone.. Steps for that are outlined in your user-manual. HOWEVER - To use a repeater the radio must be GMRS repeater-capable, and based on the Rugged Radio Product page for the GMR2+, it does not appear to be repeater capable - and if that is the case, then you bought the wrong radios. EDIT/UPDATE: After reading the user-manual for you i can see that this radio is repeater capable.. I can also see that this is probably the most confuckulating to use GMRS radio I have ever seen. I give it two thumbs down and would NOT recommend this radio to someone that does not know anything about GMRS, Tones, or repeaters..
  12. The original post said you want to find a way to edit the firmware so your MXT500 can transmit on 463.200 Megs and receive on 462.700 Megs as a channel pair. 463.200 is a Business Radio Service freq in the Part 90.35 subpart C in the Business/Industrial Pool. You can not do that legally with that radio and you need a Radio Station Authorization to transmit on 463.200 Megs
  13. Hi everyone im new to gmrs. WRYK399. I bought the gmr2+ rugged radios. Im trying to learn how to program offsets and tones into the radio but can't find anything on how to do this. I want to reach a repeater im my local area. The verdugo repeater in glendale, ca. Any help would be appreciated. Jay WRYK399
  14. Yesterday
  15. OK got it - I was using some info from a local radio club but it specified the repeater info incorreclty. Thanks
  16. I'll add to what Steve posted. Here is a link showing the only authorized channels for GMRS. https://www.buytwowayradios.com/blog/2022/11/list-of-gmrs-frequencies-and-channels.html You can't just pick any frequency between 462 MHz and 467 MHz and use them on GMRS. You have to stick with the designated channels. Midland radios will not transmit on anything other than designated GMRS channels. I have yet to see anyone hack a Midland radio.
  17. Those are not inclusive endpoints to a GMRS band. The only frequencies you are allowed to transmit on with your GMRS license are specified in the regulations: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E/section-95.1763
  18. GMRS frequencies are 462 MHz and 467 MHz so these frequencies I mentioned are withing that range.
  19. 463.200 is not a GMRS frequency. The MXT500 is a GMRS radio. Midland is pretty good about abiding by the GMRS frequency requirements. It’s highly unlikely you will be able to transmit on any non-GMRS frequency.
  20. I don't believe anyone has edited the firmware to push beyond the GMRS operating band range of the MXT500 radio. In most cases, It would be easier and cheaper just to acquire a Part 90 radio such as a Kenwood TK880 or TK8180 radio.
  21. I am trying to specify a receive frequency of 462.7000 and transmit frequency of 463.2000 on my Midland MXT500 using their PC programming software. I can specify any receive frequency but the transmit frequencies are only pre-specified via a pull-down list for regular channels, and I can't seem to edit the repeater channel frequencies at all. Larry
  22. I had 2 of the 17 Pro GPS radios and while I could get them programmed with the modified software the batteries would drain overnight. Something in the radio would cause a full power battery to glitch to half then back up to full so something wasn't right.
  23. I am very new to GMRS, the reason I got into this is because I like camping and it seems like a lot of campers use radios. I got my license and bought 2 hand held units. I have 2 Tidradio TD-H3 units, I am trying to program a local repeater (Pike Peak) I have the frequency 462.67500, and the tone 141.3 hz, I have also added the offset. I did this before and when I pressed the PTT button I got a morse code back from the repeater. After messing around with my radios for a while I decided to reset the radio and add more repeaters for a trip I am planning to take over the Olympic forest. I am using ODMASTER on both my phone and computer to program the radio units, I tried CHIRP but my computer does not have a USB A port, and my adapters dont seem to work with CHIRP. Now, I dont get a beep back from the repeater, could be that its down, I have actually driven to be about a quarter of a mile from the repeater and I believe its in line of sight and still get nothing back. I did note that when I press the PTT button the frequency changes to 467.675 as it should. I am using the TD-771 antenna on my radio (not sure that is the correct one to use). And if I have both radios on hand, I can see that sometimes when pressing the PTT on radio 1, the other (radio 2) receives signal, but nothing comes through in form of sound, it just springs into life and shows the little green arrow that indicates its receiving signal. And also, regardless of what is in the other BAND on radio 2 (receiving radio), can be a GRMS simplex channel, static comes through after a couple of seconds of holding the PTT button on radio 1. Can this just be interference? Am I doing something wrong? can it be that the repeater is just down? am I missing something in the programing? (I have tried programing with ODMASTER and on the device itself and get the same results). Both radios have the TD 771 antenna that came with them installed, I can switch to the smaller antenna (UHF:400-470 MHz) that also came with the radios but I get the same result. I have tested the radios by using simplex channels and they work up to 3-4 miles away. And I can hear people on other simplex channels.
  24. Does anyone have either of these and if so how well do they work? I've heard big praise for the BF-F8HP Pro but not much about the UV-28. Both are supposed to have GPS. Any info ya'll can give would be much appreciated.
  25. Randy's antenna is between 0' and 45,000' at or above sea level. This is why he gets to look down on we lowly peasants from his ivory tower on that glowing hillside somewhere between Seattle and Baja.
  26. WRUE951
    Antenna
    i had a plate that came with my Surecom and lost it somewhere. Never used it. In fact, i have never bothered to check SWR on my HT's.. They are designed to withstand high SWR in various conditions.. I wouldn't worry about it. You would probaly spend more for a plate than another Baofeng Radio anyway
  27. Welcome! and, just FYI - if you plan on using that plate for measuring the SWR on handheld antennas, dont bother. Even with the plate, you will never get a true/accurate SWR reading that reflects how the antenna will perform when used on the handheld. Some say this is why they stopped including the (virtually useless) plates with the meter.
  28. Welcome to the forum!
