You can also have them add a code name to the call sign to keep track of folks. My son Adam could use "Alpha" or you could just use a number so I'd be "WSAA635/1" and he could be "WSAA635/2", etc.
To be fully compliant, yes and yes. Most people don’t.
Hello, Brand new to the GMRS community. Purchased a set of radios for out door use with my adult family members. Since family members are using the radios under my license I am assuming each family member using the radio must use my call sign, is that correct? What if we are talking to each other, do we both need to sign on/off with the call sign or just one of us? Thanks for your help, CO
ChrisO83 joined the community
I only have my GMRS license but I am a "Radio Dork" for sure.
TerriKennedy reacted to a post in a topic: Baofeng BF-F8HP Pro vs UV-28 Plus.
SteveShannon reacted to a post in a topic: Baofeng BF-F8HP Pro vs UV-28 Plus.
WSIT796 joined the community
Not to totally change the subject but I can here the local Poportillo's Drive Thru radio that's about 1.5 miles away. It's crazy listening to the orders and what food costs there.
WSAA635 changed their profile photo
WSCP567 joined the community
JSCLARK10 joined the community
Normally I can hit the Shaw Butte repeater on North Mountain but for the last 2 days I get nothing, not even the static from the repeater opening. Does anyone know if they're still up or are they down for repair or something else? Thanks.
RayDiddio reacted to a post in a topic: Very new to the GMRS World
WSJC614 joined the community
amaff started following Very new to the GMRS World
All 22 non-repeater channels are shared GMRS / FRS. "Need" is a strong word. Like @OffRoaderX said, no one knows you're not using FRS radios, which don't require call signs. Especially when you're out in the woods in a hollow where no one else is going to be listening in. Basically no one I'm out and about with 'doing stuff' (and using radios for comms) with is a 'radio person' and we basically use them like FRS radios.
I did end up getting the BF-F8HP and my first impressions are WOW!, this is THE radio I've been looking for. It just works,no craziness, you just program it(with your software, thank you for that) and it does what you ask of it. I'll have to pick another one up with the coupon code when funds allow. Another HUGE plus for me is that batteries are the same as my 5 AR/UV 5RM radios so I can stock up on them and use them in both radios. Anyway, thanks for the reply, I can't wait yo do a review on this radio for my YouTube channel.
WRVS658 replied to OffRoaderX's topic in Equipment Reviews
Any further updates on any RPT50 failures or does all seem working as it should? My Motorola CM200 shot craps (due to low duty cycle I suspect) and am considering bucking up for the Btech repeater. Thanks… Doug -
amaff reacted to a post in a topic: Very new to the GMRS World
SteveShannon reacted to a post in a topic: Very new to the GMRS World
If you’re using a GMRS radio the regulations require you to identify every 15 minutes when talking and when you stop talking. For most people that really only requires you to say your call sign once at the end of the conversation. There are no FRS channels that are not also GMRS channels.
According to the FCCs, if you are using a GMRS radio, no matter what channel you are on, the answer is YES.. In the real world, and knowing that nobody listening cares, the FCCs dont care, and nobody will know what kind of radio you are using, the answer is NO.
WRVS658 joined the community
I was very favorably impressed by the Midland Ghost antenna. If I didn't need one with multi-band capability, I'd still be using it.
WRTC928 reacted to an answer to a question: Programing a rugged radio GMR2+
WSJE500 started following Very new to the GMRS World
Hello All, I just recently received my call sign, (WSJE500), and my two new Boafeng G11S radios should hopefully arrive today, or maybe tomorrow. I have zero experience with GMRS. The catalyst for embarking on this endeavour, was a hunting trip that I take annually. Cell phones do not work in that area, and my cheap FRS radios, sound like I'm talking to a deranged popcorn popper. In addition, I find this subject interesting. I understand that the G11S isn't waterproof, but I very rarely hunt in inclement weather and always carry a good supply of ziplock bags. I know it is only 3W, but they were only $40. Anyway, we will see where this takes me. It'll be me and my two adult sons, all on the same side of a ridge. The only available repeater is 15 miles away on the opposite side on an adjacent ridge. We will be down in the hollow. I have very low hopes of ever being able to hit that repeater. I will be ordering two additional radios, four total. These additional two will also be G11S as long as I am happy with the first two. This decision in based on the simplicity of the radios and the lack of experience that anyone in this party had with radios. One quick question: If I am using one of the FRS channels, do I really need to announce my call sign every 15 minutes? It appears that channels 1-7 are all FRS/GMRS and 5-watt, of which I only have 3 watts available. WSJE500 in Manchester, Tennessee - Out. :)
jwilkers reacted to an answer to a question: Grounding plate
amaff started following Tidradio TD-H3 weird behavior
Have you tried shouting your call-sign on the repeater and seeing if anyone else can hear you? With both radios side by side like you describe, you're de-sensing the receiving radio while you're transmitting to the repeater so it won't 'hear' much of anything until you come off the button. Try talking, see if you get anywhere. Or have someone hold the other radio some distance away and see if they can hear you.
amaff reacted to an answer to a question: Tidradio TD-H3 weird behavior
WSJE500 joined the community
WRXB215 reacted to a post in a topic: Baofeng BF-F8HP Pro vs UV-28 Plus.
WSIZ939 joined the community
I wrote the CPS for the BF-F8HP Pro and co-manage firmware development, as well as dabbling in manuals and marketing. The BF-F8HP Pro has user-upgradable firmware and the upgrade tool is integrated into the CPS. There have been 3 public releases of firmware (V29, V33 and V44) and there will likely be ongoing future releases. The radio you bought on the first day it was available (October 1, 2024), today, and at some indefinite point in the future will all be able to run the latest firmware. Feedback from users here, on Facebook and elsewhere gets evaluated and often results in new features and/or bug fixes. I don't know anything about the UV-28 Plus - I stopped collecting random Baofeng models once I got involved in the BF-F8HP Pro project. BTW, you can get 20% off the BF-F8HP Pro (radio only, not accessories or other models) on the https://baofengtech.com web site (not Amazon) by using coupon code "CPS" at checkout. * It should be obvious that I'm involved with the BF-F8HP Pro project, but here's a disclaimer anyway.
dogfarts2021 started following WRQX508
WRQX508 joined the community
The Wal-Mart I shop at uses 2 different models of Motorola MURS h-t's, they used to use one or two Ritron MURS base stations, but with the stock antennas on both the Motorolas & the Ritron, no roof antenna there Next time I go, I'll have to see how far away I can copy them
LeoG started following Tidradio TD-H3 weird behavior
A repeater may not always give you the ID back. It's usually on a timer (15 min) and will only ID after that time has expired. If you are receiving a signal back pressing the PTT you are hitting the repeater.
They definitely gave you the wrong information. They gave you the offset for VHF repeaters which is 0.600 MHz. And that is why you came up with 463.300 MHz The correct offset for GMRS is 5.000 MHz which will give you the correct offset frequency of 467.700 MHz. GMRS repeater channels always use a positive offset of 5 MHz. Your radio will transmit on 467.700 and receive on 462.700. The repeater will transmit on 462.700 and receive on 467.700
Well, i got the so called unlocked UV5R today.. It's not a UV5R but rather a BFH6.. I contacted the seller and he said i requested a unlocked radio to 520 and that is the model he can ship for my request. $29 bucks.. I aint gonna complain. it is unlocked and i think it's a tri band.. No manual either. I never heard of this model but it looks decent..
WSJE437 joined the community
The GMR2+ is a GMRS radio so you dont have to worry about, or even think about offsets - you just select the correct "Repeater Channel" and enter the TX tone and (optionally) the RX tone.. Steps for that are outlined in your user-manual. HOWEVER - To use a repeater the radio must be GMRS repeater-capable, and based on the Rugged Radio Product page for the GMR2+, it does not appear to be repeater capable - and if that is the case, then you bought the wrong radios. EDIT/UPDATE: After reading the user-manual for you i can see that this radio is repeater capable.. I can also see that this is probably the most confuckulating to use GMRS radio I have ever seen. I give it two thumbs down and would NOT recommend this radio to someone that does not know anything about GMRS, Tones, or repeaters..
The original post said you want to find a way to edit the firmware so your MXT500 can transmit on 463.200 Megs and receive on 462.700 Megs as a channel pair. 463.200 is a Business Radio Service freq in the Part 90.35 subpart C in the Business/Industrial Pool. You can not do that legally with that radio and you need a Radio Station Authorization to transmit on 463.200 Megs
Hi everyone im new to gmrs. WRYK399. I bought the gmr2+ rugged radios. Im trying to learn how to program offsets and tones into the radio but can't find anything on how to do this. I want to reach a repeater im my local area. The verdugo repeater in glendale, ca. Any help would be appreciated. Jay WRYK399
I'll add to what Steve posted. Here is a link showing the only authorized channels for GMRS. https://www.buytwowayradios.com/blog/2022/11/list-of-gmrs-frequencies-and-channels.html You can't just pick any frequency between 462 MHz and 467 MHz and use them on GMRS. You have to stick with the designated channels. Midland radios will not transmit on anything other than designated GMRS channels. I have yet to see anyone hack a Midland radio.
