WRBK882
Everything posted by WRBK882
  1. It appears the linking option sold by myGMRS has been out of stock for quite a while, as well as the SD card image. I understand the chip shortage has limited their access to Raspberry PI boards. Are there any other options? Possibility using a cheap Windows PC, one of the numerous Arduino’s, or any of the other single board computers? Not trying to start a fire storm, just seeing if there are options available that I am not aware of. Albert WRBK882
  2. Has anyone else had to modify their antenna connection on the Retevis RT97S to make a secure connection? I had to remove the lock washer on the SO-239 to be able to tighten the coax cable. The screw nut would tighten but the actual center connection was still loose. (No reliable outer shield/ground connection) I am using the Retevis 50' cable and antenna that came with the bundle. Kind of odd???? Albert WRBK882
