Dune 88, you are overthinking the problem. Do you have programming software for the radio? Its a spreadsheet type of program that you input the freqs and corresponding offsets, some are "+ " and some are "-". Its usally very simple to do. The only problems you can run into are "com port" issues, etc. How are you programming?
Hi, You should be RX on 462 and TX on 467. The setup will take your +5 offset and add it to the 462.xxx to give you the 467.xxx The dual watch is for monitoring two freqs that you like to listen to. Anyway, try what I suggested.
