Does 5 Mhz offset prohibits use by the XMT115 and other common lower cost GMRS radios with repeaters ? Nothing in the XMT115 manual refers to this offset. Or how to change the offset. It does speak of the access codes, but not an offset. Is the offset "fixed" in the radio such as the XMT400, XMT275, and the XMT115 ? Whereas the access codes and "fixed" offset is not a feature in the lower cost HT's ? By way of example, here is data from a repeater: Network: [None] Type: Open System Updated: August 10, 2018 Travel Tone: Yes ORI: Yes Apprx. Range: 13 Miles Output: 462.675 MHz 141.3 Hz Input: 467.675 MHz 141.3 Hz "Repeaters are by definition "half-duplex" since they use separate transmit and receive frequencies. They are called half-duplex because your radio cannot transmit and receive at the same time." Can I assume, that lower cost HTs are only capable simplex operation and are not " half duplex" capable ? That they both transmit and receive on the same frequency ? I apologize for beating a dead horse, I'm a bit confused by what the manual indicates or fails to explain and the overall operation of repeaters with GMRS radios. Thanks again for your patience. Regards, Rich
