idahofluke
Everything posted by idahofluke
  1. Ooops I’m the owner of a couple machines in Idaho falls, and west Yellowstone, I also have a 220 ham machine set up on one of the mountaintops, Id like to see about helping out in twin... maybe linking sone machines up for a bigger foot print, both gmrs and ham 220.
  2. Did you ever figure out the issue? My node has started giving connection failed when trying to connect To hubs that I’ve previously connected to. But my other node Appears to work fine still
  3. I just went through this with a few b tech 50x1s so each of the freqs 1-30 are hard coded to the radio and cant be changed.... 1-7 ar the frs/gmrs and low power, you can change the name and the tone but the freq and power will always revert back to the factory set. 8-14 and set for frs 8-14 and are RX ONLY 15-30 are able to go to the High power TX, 23-30 are the repeater input spots, so if you need to program a repeater freq or a 550 repeater then it HAS to go on the slot 23 and 575 on 24 ect thus you are not able to program multiples of the same freq but different slots... 31-256 are RX only IF you try to add, say 462.550 it will work as expected if put into slot 15, but if you try to put 462.550 into slot 16 everything appears to be ok, until you write to the radio, slot 16 will change back to 462.575 even though the name you added and tone are saved. the same is true for the repeater channels, they can only be in the 23-30 slots on chirp, 23 being 15 in etc hope this helps someone out.
  4. thank you for the info. I am looking forward to getting my wife on a radio and start hitting local repeaters.
  5. Hello, I recently got my ham call sign, I also received my GMRS Call sign to use with my wife and kids. I am unclear on how this will work... I understand the GMRS license covers your intimidate family. So would we all use the came call sign? or would I use it at the start of the contact.? coming from the Ham side I am leaning to the use at the start of contact then 10 min etc etc, but I cant find the proper use with multiple people under the same call sign. thanks for any input.
