Penneraz
Penneraz's Achievements
  1. How can the speaker on the TK-880 I just purchased on ebay be relocated from top to bottom?
  2. I appreciate your offer for help but I've resolved my issue. Thanks!
  3. Hi all. I tried a search but couldn't find an existing discussion already about problems programming the Wouxun KG-805G. I purchased the factory programming cable and software along with the radio but have run into a problem I can seem to resolve. After installing the software and connecting the radio with the cable which says by the way "support win10" which my laptop has I get an Failed Connection error message. Following Two Way Radios awesome videos I discovered that you need to select the correct "comm port" in order to communicate with the radio. However in my case all choices are greyed out and I can't get it to connect to my PC. Any ideas how to solve the connection issue? *UPDATE* I solved the problem by installed the drivers from the CD provided. My bad (slap forehead)
  4. To the Op... which Kenwood radio 880 or 863 did you decide on? I'm a newbie and doing similar research for install on my Rzr. Where I'm located there is a excellent repeater that I've been using my HT on and would cover the trails that I ride on as well.
