I inquired about BTech advertizing. Background They say in their ads for the GMRS 50X1 that there are 8 "modifiable" channels. While that is technically correct, you MAY NOT change the frequencies of any of these 8 channels. I have access to a couple of repeaters that use the same frequency, but with different tones. It's hard to know, sometimes which is which, on the same channel. So, I wanted to reprogram one of these unused 8 channels, with a duplicate frequency, and store it in one of the 8 unused channels. BUT the 50X1 cannot be changed. It keeps reverting back to the original frequency. I asked BTech engineering and they say it's very easy to do by "quick" access to the tone menu. Well that "quick" access requires a minimum of 8 key strokes on the mic. Or lots of scrolling from the radio. They also said the FCC prohibits that. I believe they are wrong and just using the FCC as an excuse. This is a Memory Channel. The FCC says nothing about how memory channels can be used or which frequency can go on which memory channel. I believe the FCC only prohibits the user from selecting a frequency and using it outside the certified limits. But BTech puts this on the FCC. Solutions Option 1: They could just make it clear in their advertisement that while the 8 "modifiable" channels are modifiable, the frequency is not. I think most people reading that would think the frequency would also be modifiable (although ONLY within the repeater frequency options) but it is not. Option 2: BTech could very easily have "hard coded" channels for the first 30, like they do now. All parameters that are allowed to be changed can be, like they are now. Frequencies can't be changed. For all the rest of the channels, they could be receive only, EXCEPT for copies, of existing hard coded channels. For instance, channels 1-30 are hard coded, you can't change frequencies. It would be very easy in software, to allow COPIES of these 30, to any of the other channels, and have them modifiable, and allow transmit, WITHOUT allowing the frequency to be changed These other channels would just be pointers to the existing hard coded channels, BUT allow parameters to be modified, per the channel in question. So, if you copied CH1 to CH40, You could operate channel 40 as it was in CH1, but only be allowed to change parameters per what was allowed in CH1. This would allow 2 legally hard coded GMRS repeater frequencies, to have different channels, on the same frequency, with different tones. I doubt this would be a violation of the FCC. Where am I wrong? If I am. And if I'm right, this would add a very useful feature. Mike GM
