RICK was replaced with the ID-O-Matic. The Duplexers were tested specifically with the GM300. So yeah, not really anything special, but at least I know the equipment was parred well from factory
I have two duplexers coming in from China that are supposedly designed for the GM300. Each tuned to unique frequencies. I will test both deviation from those, and separately, using two different antenna's. I will report back my findings here. Thank you everyone for the swift input! Here is the rig when everything gets here (waiting for ant's and dups): 1x GR300 2x GM300 1x ID-O-Matic II 2x DPD GMRS Tuned 4dbi Ant 1x 50Watt UHF 6 Cavity Duplexer RX 467.725 TX 462.725 1x 20W UHF 6 Cavity Mini Duplexer RX 467.650 TX 462.650
I have a GM300 setup, but now I need a duplexer. Is it possible to get one tuned for RX "467.xxx" and TX "462.xxx" and not the /exact/ frequency? I would like to hop between frequencies as I travel without having to pull out a duplexer for each pair. Also, if I want to scrap the duplexer idea altogether and just do two antennas, any thoughts on distance between the two (at 10watts)? Regards, KQUN760
