64
Everything posted by gortex2
Not really surprising at all. Most of the Trunk Systems where analog (still some are) in the early days. There are alot of XTL and XTS that were ordered that way. Also alot of the "rebanded" radios (800mhz) had wierd feature sets and none included digital. Remember when those radios came out digital was an option. We have some SAR radios like this becuse we couldn't justify digital just to have and we only bought 2 radios....imagine an agency buying hundredds. That could add up fast.
TX power has nothing to do with reception. If you are on the edge of the repeaters coverage then have 3db of loss in cable that's most likely your issue. A 50 watt radio will not receive any better than a 5 watt radio. Depending on the repeater this may be your issue.
Nothing is standard. It can have software ADP depending on the flash code of the radio. Q667 was the Software ADP option. You really need to run the flash code from the radio you are looking at to determine which options it has. I have multiple XTS portables that have no secure in the flash code.
So some clarification on ADP on MSI gear. Yes some MSI gear came with software ADP, but not all of them. It was a flash code option. I have XTL2500's for SAR that have Hardware ADP/AES as once you add any other encryption you need to be hardware. When the APX series came out ADP was standard and free. That has changed to a option but still can be had. Regardless of secure type (ADP, AES, DES, DES-XL, DES-OFB) if its set for hardware with a MACE board you will need a key loader of some sort to load keys. Also when you apply for your license you will need to determine your modulation. You can have multiple on the channel but make sure they add it to the license while applying. Adding DMR/P25 to your analog emission is what a lot do. If you know your never doing DMR then dont worry about it but again its part of your license. I'll add DMR is a more economical digital standard for B&I stuff where as P25 is the standard in Public Safety. The reason really boils down to cost. Yes you can buy used LMR gear but if your looking at new stuff a XPR is a 1/4 of an APX. Also if your only looking for a few portables, repeater and maybe a few mobiles talk to you local LMR dealers. Alot run a SMR system (most likely DMR) and you can rent airtime and not worry about repeater sites, maintenance etc required with your own stuff. And it allows you to dabble with a service until you decide what you want to do. When I was in the shop days I think it was $15.00 a month per radio and got alot of folks on the air over night per say. Definately do research if this is for a business use. Sometimes a basic simplex system is all you really do need..
Back to FCC licensing. As said above find a frequency coordinator. Also depending on the "business" service it may require a certain coordinator. Not all coordinators deal with all services in regards to that. Public Safety coordinators normally focus on that while other focus on B&I frequencies. Also depending on your location the license can take forever (Above Line A) as it will need to go to Canada for approval. It took us over 2 years to get approval for the last SAR frequency we got in NY. In the south a standard business license will be processed by your coordinator and then tru the FCC pretty quickly. It will also depend on if your looking for just simplex channels or repeater or multisite repeaters. Thats really were the coordinator and your self need to do some work.
gortex2 replied to SvenMarbles's topic in General Discussion
I test every radio I get in my house. I dont video them or normally document a ton of stuff becasue if I did I'd have piles of documentation that I just dont have room for. I utilize both a R2670 General Dynamics and my Anritzu LMR Master (later mostly now). Personally @marcspaz spent way more time I would arguing with someone over did he or did he not test something. Some of on this forum work in the LMR field and do indeed have knowledge and equipment to do this. Sorry if many of you dont understand this but its a reality. I didn't get where I am working for a lead LMR manufacturer by not knowing what I was doing. @marcspaz is in the same boat. There are others on here. Learn from those folks. WE have lost a few good techs from this site over threads like this. -
What is going on with the FCC ULS and CORES?
gortex2 replied to 73blazer's topic in General Discussion
ITs been like this for a week now. I have multiple changes to process. Guessing the squirrels took a nap. -
Kenwood TKR-840-1 K UHF 450-480 32 Channel Repeater
gortex2 replied to WRWH978's topic in Equipment Reviews
They only put out 5 watts on TX. I run the VHF version for some of my SAR sites and they all run thru a TPL 100 watt amplifier. Thats how they would ship when purchased new. They are a solid little unit so If your looking for a commercially made unit that will last this is one to use. -
Correct. I have MSI radios in every vehicle I own as well as all our SAR folks and friends all run Motorola. I have Midlands in my parents Jeep and my Jeeps for simplicity. Thats why I dont have RAS enabled at this time. But its not been an issue for me. If it does I'll swap my parents Midland out for XTL's. They are really the only non MSI radio using the repeaters as I use my APX when I'm on repeaters. All the rest of us use MSI radios.
I guess this really goes back to use case. Each use may be different. I own 6 repeaters. 1 is an open repeater although not listed here. All of mine are funded and maintained by myself. They are for my family and friends use only. Personally I dont want to wake up at 2am with 2 guys jabbering about his big toe that needs fungus removed. Between electric and tower fees its not a cheap endevor for some repeaters so thats my take. If someone wants a repeater to talk to there family I can see it being closed. Ive been doing this for ovder 30 years and while GMRS has changed I still use it for the same reason my parents used it for. Internal communications. Back to topic on hand. As said it can't be blocked but can be limited. All my repeaters used split DPL/CTCSS tones. Motorola offered RAS on some of the repeaters and has been used with great success. I've not needed to use it yet but if it gets to a point I may turn it on.
What do you all use for antennas at home?
gortex2 replied to WRYC373's question in Technical Discussion
Laird 4605 on house and DB404 on Garage/Shop. -
I run the InReach Explorer and from a SAR experience side I'd recommend a Montana or 67. The Explorer is ok with navigational stuff but its limmited. I still carry my Garmin 60CSX along with my InReach when on a misison. The one nice thing about the Explorer is it does have a vehicle mount. I'd like one for my JT so the wife alwasy has one. Both will also sync to my Garmin Overlander GPS and its way easier to send messages on the tablet than the little screen.
Starting with a base would be smart. If a base can't talk then a repeater wont fix that. Go with good cable and a decent antenna and you'll get a good idea on coverage.
Sorry I thought we were on a GMRS website. We get spun up in arguments over ID'ing your repeaters and everything else but daily conversations over how to mod your ham radio to use with GMRS. This is a HAM radio. Go to a HAM radio site and talk about it. Its also a CCR in a box. If your annoyed call Baofeng and tell them. Most likely they dont give a rats a$$ about it. But then again if it fits your youtube stuff I guess its all your gospel.
Why no state issued GMRS call sign license plates?
gortex2 replied to Lscott's topic in General Discussion
The local club near me still offers an in person class. -
My InReach works just fine without HF.....I get it worked but too many people rely on ham radio when it wont work.
Jungle Site for me...comes as one kit
A question about extending repeater coverage
gortex2 replied to password's topic in FCC Rules Discussion
The problem with that solution is you tie up multiple frequencies sometimes in a large area. the best way is called simulcast but its not cheap and requires the proper gear. I ran a simulcast system for some time and it works great. Many public safety systems are simulcast which is how officers have on hip portable coverage. There are very few out there who run simulcast on GMRS and HAM just because its not plug and play. For myself I run multiple repeaters. Most are all same frequency with different RX DPL tones. Same TX CTCSS. This is referred to as a poor mans voter but works well for my use case. I dont need to talk 100 miles and if I do I pick up my cell phone. -
Had one in my old camper for GMRS and would work all weekend on one battery. I carry one in the back of the jeep with my tools.
This is why my repeaters are not listed or open to anyone other than my friends and family. No ham BS on my repeaters. Its sad that we are at this point but you can't put toothpaste back in the tube. Its ultimately up to the owner of the repeater to police what he allows. My gripe is having to listen to the crap while in scan. Normally I just pop it out of scan when they go on about the doctor and the cat that fell out of the tree.
Anyone use a COMPACTenna LMR-1 for GMRS?
I know folks that use it in the LMR world and have great results. I have yet to use one just becasue my use case is different. -
Will Yaesu 6000r with ATAS120 tune gmrs?
gortex2 replied to WSBA587's question in Technical Discussion
No reason for a screwdrive to remotely go that high. A $5.00 quarter wave would work better. -
No it has to do with HAM radio being a "emergency prepardness" and "civil defence" tool in the old days. MAny areas adopted rules to exempt certain stuff. In todays world it really doesn't do what hams preach about but as with other rules they are there and dont normally change. Some areas have absolutely no restrictions on towers yet some are vvery strick on what and where a tower were to go.
