Thanks for the reply. too any one Only 3 scans I need on gmrs List 1 575 List 2 600 List 3 625 all on m1 normal then start ch Zone is on zone 1. after list 10 Scan setting Stop A (sec not sure) stop B ( sec) not sure Resume 5.00 ,talk back 10.00 ,fast scan 0.100 Slow scan 0.500 power on scan ( on) Key & Display assign on scan A start/stop Thanks who responds
Thank you for the reply I’m gonna get back into the scanned list and see if anything is set up the right way maybe it doesn’t act like the radio I’m used to see scanning we can physically see the frequency scan maybe this handheld stays on a priority channel and you don’t see the scan actually until it makes active -I’m new to icom - i’ll probably key up on the other radio I have and see if it does stop on that frequency like you said ! i’m in the process of Re-writing The ic6020 for gmrs as well Hopefully by the time I figure out the handheld I should be able to program this radio scanning with no problem thanks again Todd WRDN973
Question Does this hand held f80t scan channels i've set it up on GMRS, frequencies code plug file is at full programming mode everything works it has scan list and scanning set up in the code plug programming I just can't see where it's scanning or if it's scanning any thoughts Thanks
In order to get inside your radio to make it how you like it you have to get a data cable then download the software to add or take away changes it’s not gonna do anything to go outside the GRMS protocol per FCC I found a download link somewhere on this form for the MXT 400 I don’t have it on my phone or my computer hope it helps
Hi I have a couple mobile and some handheld that have dual watch on it no problem with them just The mxt115 you can stop on the channel you wanna listen to but there’s no Duel watch on it I only use two channels 575 and 600 repeter I would love to skip all the rest but I don’t think you can like on the MXt 400 I can skip channels (base station)I just have the last eight repeater channels customize with the name of the towns per ch
3200/3207 CAN YOU USE 3200 PROGRAMMING TO WORK WITH 3207 /2M-70CM IF YOU CANT IS IT BECAUSE IT HAS UHF PICK UP A USED ONE IM ONLY 70CM CHIRP HAS 3200 PROGRAM
THE RT76P SOFTWARE FROM THERE WEB SITE WORKS BUT EVERYTIME YOU PLUG IN YOU HAVE TO WRITE TO RADIO WHICH MESSES EVERTHING UP TO FACTORY ALL PL GONE OFFSETS GONE EX EX YOU CAN NOT CLOSE OUT MAKE SURE YOUR 100% DONE YOU CAN GO BACK TO ADJUST THEN READ TO RADIO BACK TO SQ 1 IF YOU CLOSE OUT HOPEFULLY CHIRP SOON
