billtrout
billtrout's Achievements
  1. I was out with my ht when I went to call a local repeater the radio normaly reaches i could not reach. When I got home I checked the radio on a meter and I had zero output power. I turned back off and called btwr to get a rma number very good people, so I turned it back on just too double check and now it's working fine, I am returning it but what could cause the issue? TIA Bill
  2. OK thanks figured that was it thanks Bill
  3. I'm using a wouxun 805g and trying too access a repeater and it needs a DPL code of 445. I don't see that listed in the menu options I have DCS and CTCS. Help please and yes I'm new at this Thanks Bill
  4. Gman, you may be right about that sw33 and i now have an account with Motorola salutions witch is where i got those antennas from. I also am using a 771g that seems to work well its just a tad long
  5. The Motorola antennas got in and I'm getting a 4 on them, I'm getting a bit confused I'm using an sw33 by surecom for a meter.
  6. You are correct the smiley has an swr of 8! i will be returning that and trying the Motorola antenna thanks Bill
  7. I just tried a Diamond SRJ-77CA and swr was about perfect and recieve jumped bit. That antenna is not even rated for GMRS I keep it on my yaesu ft-65. Thanks Bill
  8. OK thanks, i will check it and i looked the Motorola antenna you referenced how is the range on such short antenna? Kindest Regards Bill
  9. What was the issue with the smiley antennas? I just ordered a uhf 5/8 wave tuned at 465 thanks Bill
  10. Anybody try a smiley antenna tuned 5/8 wave tuned at 465?
  11. New member and newly licensed, this site is a wealth of information. Thanks for letting me in Bill, WRKH288
