jk06
Everything posted by jk06
  1. Nevermind, I managed to play around with the naming from freq to channel number Sent from my iPhone using Tapatalk Pro
  2. Newbie here Purchased the kg 805g and in the process of adding tones for local repeater here in the Seattle area I somehow manage to get Stuck in what appears to be a frequency choice. Is there a reset option to start over? Sent from my iPhone using Tapatalk Pro
  3. Thanks again. so, I entered code 13 for the 103.5 freq. Now, I'm looking at the DCS code chart and wondering of I have to use the same #13 for DCS? any idea?
  4. Hi I just bought the MXT 115 and wanted to see if I need to program the CTCS codes for repeaters. Thanks in advance!
  5. I am unable to use chip on my Btech GMRS v1 using Mac with Big Sur OS. However, I am able to use chirp using a Baofeng red FTDI usb cable on my BR-F8HP. Not sure if anyone reading this had a layman fix for this.
  6. Hi, Do I need to add CTCS tones in order to communicate with the GMRS v1 hard loaded Channels? Thanks
  7. Follow up question. I was provided two frequencies. 462.500/467.550. Do I need to program both freqs that were provided or just one? Thanks,
  8. I would love to use chirp but too many issues trying to work this on my macbook( big sur).
  9. Hi, I was provided access to repeaters here in Seattle. When I was in freq mode I hit the scan button and a range field appeared. Do I need to add numbers to the range field? Also when referring to Tone, is that in reference to the R CTCS and T CTCS? Finally, I have two frequencies per repeater. Do I add both or one? Very new to GMRS.. Sorry for the loaded questions!
  10. thanks for the feedback. so do you know of a step by step guidance for CTCSS/DC TONES? again, I'm new and willing to learn but not sure if the manual really helps me. thanks, John
  11. Hi, I just purchased my Btech GMRS V1 and wanted to know if I need to program in the frequencies or any other codes before using? My purpose of this is really just to see the benefits of using this type of technology. I live in western washington and was trying to reach out to anyone using GMRS but have not had any luck.
  12. could be. I also used a usb hub and that didn't work. having a blast with this..lol
  13. the is the error message states, " not the amount of data that we want" the port options are:/dev/cu.usbserial-A10KAO64. and/dev/cu.Bluetooth-Incoming-Port
  14. That’s the same, cable that I have. The MacBook allows the driver install and the chirp install. I’m stuck at the point where the chirp install options where the gmrs device isn’t recognized. Is there a cheet sheet for this install in a Apple product? Any other recommendations?
  15. I did that but still no luck, My MacBook OS is the most current version. Chirp still isn’t recognizing the device.
  16. I did that but still no luck, My MacBook OS is the most current version. Chirp still isn’t recognizing the device.
  17. Hello, Newbie here. I want to use CHIRP for my new Btech GMRS v1. i have an apple usb c to usb but my Btech doesn't show up in the CHIRP profile. what am I missing? is there an easy way to get the device recognized? Thanks, John
