Replaced connector, with the same results. 2.8 to 3.0. This time i only soldered the pin and didn't solder the shield to the plug. I read that soldering the shield can result in overheating the insulator in the wire. Also with the new connector i extended the antenna as such as i could in the mount, about 1/4 of a inch. the results were a drop in swr to 2.0 - 2.2. already ordered a new antenna but i only have the two connectors so cant try another one without getting more. Thanks for all the help. Justin WRKX762
