Oliver
Everything posted by Oliver
  1. I figured out how to do that in software, but haven't found a way to do it "on the radio".
  2. Unfortunately the UV9G has Roger beep permanently disabled. Makes no sense. Really disappointed, as I use it to trigger my store-and-forward repeater.
  3. I am glad you have been able to set your memory to a particular scan group. Please tell me how you did that. The scan group (menu 43) apparently selects the channel to be in a certain group, or does it select a group to scan? How do you assign a channel to a certain group, and how do you assign the scanner to scan a certain group? Once again, the manual falls short in explaining.
  4. I just got my Pro version today and the first thing I noticed is I cannot change the roger beep. I need it to trigger my store and forward repeater. I can set it but it doesn't stick. Where does it say that the Pro version doesn't have a Roger Beep? It has the menu for it.
  5. Just received this radio today and the first thing I wanted to do is set the roger tone, but when I change it and press menu then exit and go back it is still off. I found other menus doing the same thing. Is there some setup I need to do to make changes. Maybe I am in a memory and that is preventing me from making changes. Any ideas?
