WROJ697
WROJ697's Achievements
  1. It’s all good, you were only trying like I am! I didn’t drive out that way yet or anything so no harm, no foul. Where I’m located is close to TSTC, just a few miles east of the IH-35 corridor and just shy of a couple miles N/NW of 84. I read in an earlier post that you used to live in McGregor but moved after retiring. Are you still in Texas? If so, I just found something awesome, but you gotta pay around $25 to use it (good for a year, I think). Become a supporting member of the Texas GMRS (TexasGMRS.net) website and you get access to RO-IP, either via Android, iOS or PC, and you basically “dial-in” to a repeater that’s linked to almost every repeater in Texas and talk over wifi or cell data. My first day, I keyed up and talked to guys from Mexia, Cypress, and Troy!
  2. Than Thanks for the tip! Still no luck on my end, so I’m either too far away or no one is on the repeater when I try it. There’s no tone after I transmit so idk if I hit it or they just don’t have a beep set.
  3. Hey guys, Thanks for the prompt replies. I did include "141.3" in the tone column. Attached is a screenshot of Chirp. Does that look right? Or should I have done: Tone Mode: ToneSql ToneSql: 141.3 ?
  4. https://mygmrs.com/repeater/4727 I’m trying to program the above repeater into Chirp, and I thought I had it correct, but I’m not sure because I didn’t hear a tone or anything after I transmitted. This is what I programmed: FREQ.: 462.575 Name: WRCP705 Tone mode: Tone Duplex: + Offset: 5.0 If a column wasn’t mentioned above, I left it blank. Did I do that correctly or should I change something?
  5. Yeah, I think you’re right. I’m gonna try to hit it later tonight and let you know! Are they normally like ham repeaters, where even if no one responds, you’ll still hear a tone or some sort of Morse code? McGregor is nice. I worked out that way a lot at my last job. Lots of pretty country headed out towards Gatesville and beyond! Since you know the area, to clarify I’m actually in Bellmead, pretty much right on the line between Bellmead and Lacy Lakeview, couple miles south of TSTC. So it sits a bit low. But let’s see…
  6. I’m afraid I’m in the same boat as the OP. I live in the heart of Texas (Waco, specifically) and I got my GMRS license in hopes to do a little rag-chewing too, but all I get are crickets. I also understand that this isn’t ham radio and random contact and chatter isn’t all that common in GMRS. I’m not only interested in that side of it, but also in possibly setting up a repeater or getting HTs for my family. These are long-term goals, however, and it would be cool to just make contact once! Had I done more research, I would have seen that there are ZERO repeaters in my area (the closest being about 60 miles away) so my only shot at this is simplex (which is what, 1-2 miles line of sight?) or hitting one of the repeaters when traveling, which I’ll also try to do but not at this very moment. oh well. Lol
