AD4GC
Everything posted by AD4GC
  1. WRUW570, I am running two CDM mobiles and the ID-O-Matic 4 in my repeater setup. I have found that occasionally regardless of programming, if the receive radio's volume is turned down, as in if you can't hear yourself talking, it will not pass audio, however I get my transmit audio from pin 11 of the receiver (discriminated audio) instead of pin 5 (flat audio), this may be the difference in my situation as I have never used pin 5 of the receiver to acquire the audio for the transmitter. I have found this on more than one occasion, so that may be something to look at. Here are screenshots of the accessory pins and accessory configuration on my setup. Hope this helps.... if you still need it, I can send you the codeplugs. The Receiver Accessory Config. The Recieve Accessory Pins assignment ***Using Pin 4 and 12 is not required, I use pin 4 as a remote knockdown using MDC-1200 and DTMF and pin 12 as a Repeater Controller reset. *** The Transmitter Accessory Config And the Transmitter Accessory Pins assignment
  2. Since the conversation is titled "Need a antenna for my repeater" I'm guessing you're looking for a Repeater Antenna?.... I know, a lucky guess... I have been using a Comet CA-712EFC at just 20 feet above the ground for over a year now and have had phenominal results. The antenna link was the cheapest I quickly found, most places are out of stock but there are a few that have them in stock but at a slightly higher price.
  3. They are showing again! Thanks!
  4. Same here, I sent a bug report.
  5. Shew..... glad to know I'm not the only one. Thanks. I'll send a report.
  6. Hey fellas, I'm new to the forum, and new to GMRS. I'm not sure if this is worthy of a bug report, so before I report it, are you all able to see the repeaters on the map? I listed my repeater a couple of weeks ago, and now it doesn't even show in the "My Repeaters" or on my profile? Am I missing something? Thanks, Greg WROE979 / AD4GC
