Thanks for the information on antenna, I will go look into that. Yep I have the SW-33 as it seemed to be regarded as decent by some of the youtubers. what would be a decent one?
I think most of my confusion is around what is a good ground plane. I have read everything from it must be connected a chassis ground point but can just be a bit of angle iron, or the antenna mount must be attached through a large metal surface, or as long as the antenna sits just above a large metal surface. I the case of my placement in the picture do I have any ground plane or just a bad one?
Checked and the repeater channels are off by default on the radio, but if I change the power from hi to low on channel 22 the SWR drop to 1.34. I also tried the small magnetic mount antenna in that also came with the radio in the same location and ran the coax the same route and get a SWR or 1.12 across all channels.
