The reason you can not connect to nodes, you need to solve your DTMF problem. If and when you enter DTMF command to connect to a Node, it should say connecting to Node 177, if it fails nothing happens. Did you check the map to see if your Node shows up. 5 minutes after configuring mine it showed up on the map. I just tried to connect to your Node and it failed. been working on mine for a week now, have the Supermon going and connected to the Network. 24103
WRTX950
Dale
