WRTX950
Everything posted by WRTX950
  1. The reason you can not connect to nodes, you need to solve your DTMF problem. If and when you enter DTMF command to connect to a Node, it should say connecting to Node 177, if it fails nothing happens. Did you check the map to see if your Node shows up. 5 minutes after configuring mine it showed up on the map. I just tried to connect to your Node and it failed. been working on mine for a week now, have the Supermon going and connected to the Network. 24103 WRTX950 Dale
