A couple of other things. At the step that says "Change your crontab -e to run rc.updatenodelist", because the screenshot runs off the left edge, you can't see that there is an asterisk (shift-8) (never use the numeric keypad) at the beginning of the line. So
/5 * * * * /usr/local/etc/rc.updatenodeist should be
*/5 * * * * /usr/local/etc/rc.updatenodeist
as does the line above it for AutoSky
PS: you can make your PuTTY window look a LOT cleaner by doing the following:
In Putty,
Window...Appearance...Font... change to 18point
Translation... Remote character set make it CP437
Session...Default settings...Save
Also update any saved sessions you may have. Actually, I don't save sessions. What I do is in WinSCP I choose
Options...Preferences...Integration...Applications... and tick all 3 (versus the default middle one) and then WinSCP invokes PuTTY.
One other WinSCP tip: if you can't "see" a file that is there (example: /srv/http/supermon/.htpasswd) then click lower right to show hidden files.
You can edit files in Supermon Configuration Editor, but if it warns you about the file being read-only, go into WinSCP, go to the file such as /etc/asterisk/rpt.conf and hit F9 to change the properties of the file from 0644 to 0666
That's about it for now. 73
-Pres WRJL719/W2PW
