WRUW570
Everything posted by WRUW570
  1. I have had a GMRS repeater active running 2 Motorola M1225LS radios using an ID-O-MATIC 4 controller and everything was working very good. Unfortunately one of my M1225LS radios failed, so I thought I would use a couple CDM1250's I have that are in excellent condition. I called Dan who builds the ID-O-MATIC controller and he said that the wiring configuration that was setup for the M1225LS radios would be the same for the CDM1250's. So I hooked everything up. Opened up my CPS software, and reprogrammed the CDM1250's to work (what I thought) as a repeater. I am able to key the repeater with my handheld via the RX radio, and the ID-O-Matic keys the TX radio just as it should. The problem IS........ There is no audio passing through the controller through the TX radio. I have tried, and tried to play around with the settings to get it to work with NO LUCK. I am not at all a wizard with the CPS software by no means. (And I'm sure I have things messed up with both TX, and RX radios). Anyone have a working code-plug for the CDM1250 that will work using an ID-O-MATIC controller? I am at my wits end. All help will be GREATLY APPRECIATED!
