WSHW974 Posted July 27, 2025 Posted July 27, 2025 Similar but different from Meshtastic. Has anyone tried this. The setup was much easier than Meshtastic. Quote
WSHW974 Posted July 27, 2025 Author Posted July 27, 2025 I have two Heltec V3s set up on MeshCore. One as a repeater up about 25 feet and the other as a node here in the shack. This works differently because nodes do not repeat everything they hear so the channel does not get polluted with repeat packets. My MeshCore repeater is in Belmont Michigan. If you are near by and want to try MeshCore with your LORA rig... WSAQ296 1 Quote
