Fire18472 Posted July 14, 2018 Report Share Posted July 14, 2018 Well I did done do it....Pulled out all my old gear and fired it back up ...My old Regency Land Mobile repeater feeding into my TX-RX vari-notch duplexer a old hand me down hunk of coax (sorry not sure of the type) and into a one of those antenna kits that you can use a mobile antenna for a base like you see on construction sites, but I have a 50' piece or LMR sitting here just waiting for someones fingers to wrap around it and install it..I took an inventory of the stuff I have and it shocked me...Ritron RPM 450 mobiles looks like 6 of them not sure what shape there in, a couple of duplexers, Zetron 37 repeaterman box , a ZR 310 community panel, a 3 element YAGI antenna, 3 base antenna's,one is new I always wanted to try out one of Michael, KB9VBR, J pole antenna for GMRS, (I am using one of his other J pole antenna for my scanner for which it's got to be 5 years maybe older which it works great) the other one is Hustler G6-460, and one other that's around 6dB I think it's a maxrad ...but what ever.. still need moral support help trying to fasten the LMR to the mast I have so it won't wear thru the cover on the LMR while it's against the mast. Suggestions people ? Don WRBN575 Quote Link to comment Share on other sites More sharing options...
NavyBOFH Posted August 28, 2018 Report Share Posted August 28, 2018 What kind of mast? Are you talking about a fixed location for a repeater/base, or a push-up type mast meant to be "portable"? Either way - LMR outer insulation is pretty rugged and I have used anything from LMR400 up to 3" Heliax at sites. The way to secure most of it at towers is with "butterfly clips" which clamp the coax down to a tower leg. But in a small-use case... using black "UV resistant" heavy duty zip ties will work just fine. Your issue with possible wear of the LMR insulation won't come from a fastener - it will come from if you DON'T fasten it down and let it rub against anything and everything in the wind. I have seen towers hit by bad storms have bad coax or even waveguide from rubbing against each other for weeks or months until caught. Quote Link to comment Share on other sites More sharing options...
