ocshooter Posted October 16, 2019 Report Share Posted October 16, 2019 Hi, I've had my GMRS license for a while but haven't bothered using it since I didn't think I was in range of a repeater and LOS wouldn't help me. Well, I found a repeater in my county and want to see if I can hit it, so some basic questions if I may: Are all GMRS repeaters simplex, or do I need an input and output (uplink/downlink) setting? The repeater in question states that the National Travel Tone is active...what does that mean and what is the tone freq/is it a common freq? What settings would I enter in my Baofeng, if simplex or duplex and if a tone is needed? If I'm hitting a repeater will I hear it opening when I key the mic? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
WRAK968 Posted October 16, 2019 Report Share Posted October 16, 2019 Hello and Welcome to MyGMRS.GMRS repeaters are typically duplex, thus you would transmit on 467.xxxx and receive on 462.xxxx.NTT is 141.3 if I recall.Not sure how you would set up your radio. I guess the easiest way to set it up is to program it by computer, (which you should be doing to keep compliance of part 95) Each radio, even within the same brand, can have very different programming steps.You wont always hear the repeater when you key up unless you are listening with a second radio. Again, this varys by repeater model and the settings that were programmed. My repeater lets you hear a beep when you unkey, some have a tail, others just shut off as soon as you unkey ocshooter 1 Quote Link to comment Share on other sites More sharing options...
