Greetings folks.
I'm new here and to GMRS in general, but I'm glad I found out about GMRS.
I'm trying to set up emergency back-up communications between myself and my wife, for those times when power, internet, and cellular are out especially. Yes, not often, but it has happened. (We're in Virginia and have lived through 36+ hour power outages due to hurricanes, etc.)
My goal is to work towards simplex communications with my wife, but for now, I'll settle for a local GMRS repeater. Her office is about 3 miles away, and the terrain is fairly flat suburban area.
I'm working (for now) primarily with handheld radios. BaoFeng UV-5Rs. I plan to upgrade to at least having a base transceiver at home. (One that does 2M and 0.7M HAM as well.) But, for now, handhelds.
I have a GMRS license (WRFC813) and am sitting for my technician class ham license in a couple weeks. (I will NEVER get my wife to go ham, so don't go there. Hence, GMRS for the two of us, but ham for my own hobbyist fun.)
So, that in mind, here's my issue...
I can communicate with a nearby repeater just fine. That is, just fine from one of the handhelds when I'm outside my house. I also have a mag mount antenna on my car roof and can hit the repeater pretty much anywhere in my area.
But, when I step inside the house, I often can't quite get there.
I tried the car antenna (Nagoya UT-72) inside the house, and it doesn't seem better than the whips (NA-771). Then again, inside the house, I do not have a good ground plane steel plate on which to mount the UT-72...
I literally step out the front door or back door onto my deck and I can talk with the repeater. Inside, not so much.
Suggestions for a home antenna rig that will improve this? I'm in a HOA, so I really don't want to bother with trying to get permission from the crown to install an outdoor antenna. I have an attic crawl space, but if I'm going to go that route, I want to be pretty certain it'll work.
My preference is something that can sit here in my living room and still be enough improvement of the NA-771 that I'll be happy. Perhaps better mounting for a UT-72? Suggestions?
Thanks.
Cheers,
Ken (WRFC813)
