Thanks Michael, I did find the firmware as you suggested below...
I was having issue with one of my 805G, thinking it was the new antenna you suggest for Jeep and RV, nor was it Nagoya NA-771G.
My clue was it was not remembering the root settings like voice, display name not channel and host of other. I did follow you suggestion on using the exit. Remember I have two 805G and it works correctly.
All is good so far, did a radio check on the repeater and works great. Glad it was just a simple reinstall software.
Thanks,
Jack
I do not know for 100% certain how to determine the firmware version of the radio. The firmware version does not display in the manufacturer’s software that I have found yet. However, it may be one of the values that can be displayed on the radio if you do the following:
Power down the radio.
Press and hold the ‘Up’ button on the front of the radio.
Turn the power back on.
Release the ‘Up’ button.
Press the ‘Up’ button multiple times to step through a series of values. One of those may be firmware version.
Honestly, if I were the FCC, I would not allow field upgradeable firmware in a Personal Radio Service Radio. Doing so would open the door to greater misuse and conversion of a radio authorized for one specific service into a radio that operates on another given current hardware designs. It is mostly, if not only, the firmware today that determines whether some radios performs as one model vs another. Honestly, I would expect the FCC to mandate firmware updates be done by the Importer/manufacturer in much the same way that product recalls are handled. Updates that fix FCC compliance issues free. Feature updates perhaps at a nominal cost.
Don’t get me wrong, I am a technical person and like to do things myself. I also recognize however that there are way to many out there that would do this for nefarious reasons. The easier it is to do, the more rampant it would become. Just like folks buying certain BaoFeng radios for $29 intended for licensed amateur use only and then using them on GMRS for which they are not authorized. They are so cheap, the issue appears widespread.
Regards,
Michael
WRHS965
KE8PLM
