The antenna i'm using is:
http://www.cometante...s/uhf-antennas/
Do yourself huge favor and slip an appropriate length of shrink tube over the middle joint on the antenna to provide a much better water seal.
Posted 10 March 2017 - 11:08 AM
Posted 10 March 2017 - 11:40 AM
Speaking of the antenna. I was curious why you chose the CA-712EFC over the CA-F72GF.The antenna i'm using is:...
...CA-712EFC
Everything we hear is an opinion, not a fact. Everything we see is a perspective, not the truth.
-- Marcus Aurelius
Posted 10 March 2017 - 12:10 PM
How did you guys learn how to do all of this neat stuff? I'm struggling here with all the acronyms.
De Oppresso Liber
Posted 10 March 2017 - 06:32 PM
How did you guys learn how to do all of this neat stuff?...
By making lots of mistakes
-- Marcus Aurelius
Posted 10 March 2017 - 08:34 PM
I'm truly in the presence of greatness on this forum!
De Oppresso Liber
Posted 12 March 2017 - 10:56 PM
Sussex County, New Jersey.
I'm building a home DIY repeater system w Kenwood TK-880 & Elektra 2000
Comet CA-712EFC + (Ed Fong PVC Jpole)
Baofeng UV-5R, 888S
Motorola GR1225 Repeater - EX600XLS
Lots of research and trial and error.How did you guys learn how to do all of this neat stuff? I'm struggling here with all the acronyms.
Baofeng UV-5R, 888S
Posted 12 March 2017 - 10:59 PM
While there is no real great difference between the two for GMRS, I picked the F72GF for a couple of reasons others might want to consider. Although there was a little extra work cutting the antenna to length I was able to tune it spot on to our transmit frequency. Also, because I had to open it anyway, I was able to seal it up nice and tight on reassembly and I had a chance to check all the internal solder joints as they have a (somewhat undeserved) reputation for problems.
Baofeng UV-5R, 888S
Posted 14 March 2017 - 01:26 PM
Posted 29 March 2017 - 05:07 PM
Posted 25 June 2017 - 11:13 PM
I made some progress..... i'm keying into a dummy load for testing around the house... just need to finish mounting the controller and fans, and building out the rest of the custom cables and circuits for the utility power out alarm, and fan control relay. The idea is to have one box with everything contained that i can pull out and take home to service. Testing sounds great, no noise from power supply or tx into the controller. idle power is 15 watts draw on utility, and 40 watts on TX, and the RF tx is only around 10 watts out, im running the TX880 on low power, and i'm not sure how much power exactly, i killed my meter. But it runs very cool on TX low power. I need to get a new cross needle SWR and RF meter now.
Baofeng UV-5R, 888S
Posted 25 June 2017 - 11:16 PM
Baofeng UV-5R, 888S
Posted 26 February 2018 - 01:24 AM
I can't believe it has been almost 4 years since I started this build but finally, everything is done, solar, batteries, controller, custom cables, duplexer, control radio, control yagi antenna, mast, coax, etc. half way installed, low power, antenna only at ground level, and works great.
photos:
https://goo.gl/photo...nU5TNpzWXnXqFm9
battery low voltage alarm:
https://www.youtube....h?v=n1JL3mUtiUI
Dtmf channel control gmrs repeater kenwood TK-880
https://www.youtube....h?v=0d06MtueMWM
Baofeng UV-5R, 888S
Posted 26 February 2018 - 03:25 AM
-- Marcus Aurelius
Posted 27 February 2018 - 11:19 AM
Digging the old PC tower case. Now that you have worked out all of the bugs, are you ready to mass produce on the cheap? lol.
Posted 01 April 2018 - 01:30 PM
Love this writeup, checked in over the last year and glad to see it basically 'done'. I have a tk-880 and have been playing with doing exactly what you've done here with an H, like you I also ended up getting an off the shelf repeater (gr300) to play with as well. Also for what it's worth I have two Ed Fong antennas I have been using for over a year and though my use has been limited to HAM and GMRS repeaters not too far,I haven't had any problems yet. The small footprint being referred to was it's wind profile, not it's coverage area.
What power supply did you end up using?
Posted 01 April 2018 - 06:50 PM
0 members, 0 guests, 0 anonymous users
