WROZ437 Posted January 14 Report Share Posted January 14 Total noob here so sorry for what is probably a dumb question. I was recently granted access to a repeater in my area that uses 67.0 as it’s input tone. I have a Midland MXT275 in my Jeep. I checked the CTCSS reference chart in the manual and code 1 correlates to 67.09. Would I be correct to assume this is the same as 67.0 or will I be unable to access the repeater? Interestingly enough, code 1 (67.09) is the only one that goes beyond 1 decimal place. Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted January 14 Report Share Posted January 14 Welcome! There are NO dumb questions; only dumb answers! I do not have that radio, but my best guess it is a typo! Quote Link to comment Share on other sites More sharing options...
wayoverthere Posted January 14 Report Share Posted January 14 4 minutes ago, MichaelLAX said: I do not have that radio, but my best guess it is a typo! Given none of the other codes have 2 decimal places, I agree with Michael. My mxt115 manual has the same typo though. Quote Link to comment Share on other sites More sharing options...
WROZ437 Posted January 14 Author Report Share Posted January 14 Thanks guys! I keyed the mic and called out but didn’t get a response from the repeater. I am allegedly within range but who knows if I have my antenna in the best place etc. Also, the Jeep was sitting in the driveway and wasn’t running so the electrical system wasn’t at 13.8 volts, either. I’ll have to test range next time I am out and about. Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted January 14 Report Share Posted January 14 You do not mention any information about the repeater (location, frequency) but is it listed here on myGMRS? Take a drive much closer to it and try to hit the repeater then. And if you have an extra HT, have a family member monitor the repeater while you drive out to hit it. Quote Link to comment Share on other sites More sharing options...
H8SPVMT Posted January 14 Report Share Posted January 14 The Midland chart that I received with the MXT400 states "1" for the CTCSS code for 67.0 WITHOUT the "9" so I too am saying that must be a typo as on page 28 of your manual. When setting the code ensure are entering the CTCSS code and the DCS. Goto page 19 of your Owners Manual to see a better representation of these instructions for what will display on your screen To select a Privacy Code: 1. Press and release the Menu button to a place the radio in “Menu” mode. 2. Use the Volume Up or Volume Down button to scroll through the menu options until the LCD display shows Pt, then press the Lock button. 3. Use the Volume Up or Volume Down button to select the privacy tone type you would like to use: oF, Ct, or dC 4. Press the Lock button to confirm your selection. The (for CTCSS) or (for DCS) icon will show on the LCD display, according to your selection. 5. Use the Volume Up or Volume Down button to scroll forward or backward through the available Privacy Codes until the desired Privacy Code is shown on the LCD display. Quote Link to comment Share on other sites More sharing options...
WROZ437 Posted January 14 Author Report Share Posted January 14 26 minutes ago, MichaelLAX said: You do not mention any information about the repeater (location, frequency) but is it listed here on myGMRS? Take a drive much closer to it and try to hit the repeater then. And if you have an extra HT, have a family member monitor the repeater while you drive out to hit it. The repeater is actually fairly close to me. It is listed on this site. I learned a few minutes ago that the repeater was down for maintenance for a bit this afternoon. Pretty sure that’s when I was trying to hit it. 7 minutes ago, H8SPVMT said: The Midland chart that I received with the MXT400 states "1" for the CTCSS code for 67.0 WITHOUT the "9" so I too am saying that must be a typo as on page 28 of your manual. When setting the code ensure are entering the CTCSS code and the DCS. Goto page 19 of your Owners Manual to see a better representation of these instructions for what will display on your screen To select a Privacy Code: 1. Press and release the Menu button to a place the radio in “Menu” mode. 2. Use the Volume Up or Volume Down button to scroll through the menu options until the LCD display shows Pt, then press the Lock button. 3. Use the Volume Up or Volume Down button to select the privacy tone type you would like to use: oF, Ct, or dC 4. Press the Lock button to confirm your selection. The (for CTCSS) or (for DCS) icon will show on the LCD display, according to your selection. 5. Use the Volume Up or Volume Down button to scroll forward or backward through the available Privacy Codes until the desired Privacy Code is shown on the LCD display. Thanks. I have the radio set up properly. Pretty sure the repeater was down for maintenance when I was trying to hit it. MichaelLAX 1 Quote Link to comment Share on other sites More sharing options...
H8SPVMT Posted January 14 Report Share Posted January 14 The default squelch setting is 04, on the new 275 and I thought that maybe setting it as low as it will go will allow you to better hear the squelch return from the repeater when it does get back up and running, Best of luck! WROZ437 and MichaelLAX 2 Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted January 14 Report Share Posted January 14 OH, New Jersey... My apologies! Quote Link to comment Share on other sites More sharing options...
WROZ437 Posted January 15 Author Report Share Posted January 15 58 minutes ago, H8SPVMT said: The default squelch setting is 04, on the new 275 and I thought that maybe setting it as low as it will go will allow you to better hear the squelch return from the repeater when it does get back up and running, Best of luck! That is a fair point and I will keep it in mind if I can’t get the repeater next time I try. 41 minutes ago, MichaelLAX said: OH, New Jersey... My apologies! Since I am not from here I will accept your apologies. Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted January 15 Report Share Posted January 15 Just now, WROZ437 said: Since I am not from here I will accept your apologies. I was considering an apology until I read that it was your choice to move there! Since I'm not from NY, I really have no feud with New Jersey. Having spent time in Montana, they really have a feud with North Dakota! Quote Link to comment Share on other sites More sharing options...
WROZ437 Posted January 15 Author Report Share Posted January 15 1 minute ago, MichaelLAX said: I was considering an apology until I read that it was your choice to move there! Since I'm not from NY, I really have no feud with New Jersey. Having spent time in Montana, they really have a feud with North Dakota! Haha. Yeah, it was my choice. DOH! Moved here “temporarily” for a work opportunity, met a girl, you know the rest… Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted January 15 Report Share Posted January 15 Jersey Girl - Liv Tyler NICE! WROZ437 1 Quote Link to comment Share on other sites More sharing options...
