WROZ873 Posted January 28, 2022 Report Share Posted January 28, 2022 New to GMRS and have the KG-395G, and I think I'm starting to confuse myself. When the repeater owner lists the Input and Output tones which ones correspond to the TX and RX tones on the radio? Also I have been noticing after I try and set a tones for specific channel the tone(s) tend to go back to being set to "Off". Thoughts? Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted January 28, 2022 Report Share Posted January 28, 2022 14 minutes ago, WROZ873 said: New to GMRS and have the KG-395G, and I think I'm starting to confuse myself. When the repeater owner lists the Input and Output tones which ones correspond to the TX and RX tones on the radio? Also I have been noticing after I try and set a tones for specific channel the tone(s) tend to go back to being set to "Off". Thoughts? That’s because the KG-395 has the codes transposed from their KG-935! Quote Link to comment Share on other sites More sharing options...
WROZ873 Posted January 28, 2022 Author Report Share Posted January 28, 2022 1 minute ago, MichaelLAX said: That’s because the KG-395 has the codes transposed from their KG-935! I meant 935, sorry. Quote Link to comment Share on other sites More sharing options...
WROZ873 Posted January 28, 2022 Author Report Share Posted January 28, 2022 2 minutes ago, MichaelLAX said: That’s because the KG-395 has the codes transposed from their KG-935! I meant I have the KG-935G. Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted January 28, 2022 Report Share Posted January 28, 2022 Encode = Input = Your transmitting tone - Tx Decode = Output = Your receiving tone - Rx I recommend you not use receiving tones at least initially Quote Link to comment Share on other sites More sharing options...
Lscott Posted January 28, 2022 Report Share Posted January 28, 2022 I don’t recommend using receive tones at all except under exceptional conditions. Myself I almost never use them. I want to monitor any and all traffic on a channel. The only exceptions I have is one simplex frequency I use with a group of friends when out at large radio swap meets. The other is to block DMR traffic, from a hospital, when I’m just interested in the analog FM when monitoring a local mall security frequency. Both use the same UHF frequency. Quote Link to comment Share on other sites More sharing options...
mbrun Posted January 29, 2022 Report Share Posted January 29, 2022 New to GMRS and have the KG-395G, and I think I'm starting to confuse myself. When the repeater owner lists the Input and Output tones which ones correspond to the TX and RX tones on the radio? Also I have been noticing after I try and set a tones for specific channel the tone(s) tend to go back to being set to "Off". Thoughts? When setting tones on Wouxun radios there is a specific sequence you must follow or your tones will not be saved.Use the Menu button to access the function menu.Use the rotary control, up/down buttons, or key pad to find the function menu item you want to change.Press the Menu button to activate the function menu item.Make you selection using the rotary control or up/down buttons.Press the Menu button again to save your change.Be aware that the Menu button serves as an “activate”, “select”, and “enter” button. Failing to press Menu after making a CTCSS or DCS value will result in you value not being saved.A word of note. There is a mutually exclusive relationship between the two TX code types and the two RX codes. For example, if you set a TX CTCSS code, then go to the TX DCS function menu, active it and see that it is Off, it you then hit Menu to accept the displayed value, you are in effect clearly both TX CTCSS and TX DCS.So, if you activate a function menu to see what value it has, it is best to get in the habit of hitting Exit, rather than Menu, if you did not make a change it. Of course, if you did change it, you must hit Menu to save your change.Do some experimentation with the CTCSS and DCS menus and I am certain you will relate to what I am describing.MichaelWRHS965KE8PLM Quote Link to comment Share on other sites More sharing options...
Lscott Posted January 29, 2022 Report Share Posted January 29, 2022 I don’t have a KG-935 radio so this is just for my educational benefit. I’m a bit confused by the above. Are you saying you can’t use mixed CTCSS and DCS as spilt tones on one channel? That would be a bit restrictive having to use both tones, TX and RX, as CTCSS or DCS. Quote Link to comment Share on other sites More sharing options...
WROZ873 Posted January 29, 2022 Author Report Share Posted January 29, 2022 1 hour ago, mbrun said: When setting tones on Wouxun radios there is a specific sequence you must follow or your tones will not be saved. Use the Menu button to access the function menu. Use the rotary control, up/down buttons, or key pad to find the function menu item you want to change. Press the Menu button to activate the function menu item. Make you selection using the rotary control or up/down buttons. Press the Menu button again to save your change. Be aware that the Menu button serves as an “activate”, “select”, and “enter” button. Failing to press Menu after making a CTCSS or DCS value will result in you value not being saved. A word of note. There is a mutually exclusive relationship between the two TX code types and the two RX codes. For example, if you set a TX CTCSS code, then go to the TX DCS function menu, active it and see that it is Off, it you then hit Menu to accept the displayed value, you are in effect clearly both TX CTCSS and TX DCS. So, if you activate a function menu to see what value it has, it is best to get in the habit of hitting Exit, rather than Menu, if you did not make a change it. Of course, if you did change it, you must hit Menu to save your change. Do some experimentation with the CTCSS and DCS menus and I am certain you will relate to what I am describing. Michael WRHS965 KE8PLM Thank you. Quote Link to comment Share on other sites More sharing options...
WROZ873 Posted January 29, 2022 Author Report Share Posted January 29, 2022 4 hours ago, MichaelLAX said: Encode = Input = Your transmitting tone - Tx Decode = Output = Your receiving tone - Rx I recommend you not use receiving tones at least initially Thank you. Quote Link to comment Share on other sites More sharing options...
