I found this out by accident while playing around with some radios. Two older radios, an Icom IC-F2821 and a couple of Kenwood TK880's and a newer Icom IC-2730a.
I have been using the 2730a mostly, but stuck a cheap mobile antenna into the 2821 and started picking up a somewhat local GMRS repeater that the 2730a wasn't receiving, using an outside, roof mounted antenna. Tried the cheap mobile antenna on the 880 and also worked great, picking up the repeater. I tried the mobile antenna in the 2730 and nothing. Of course both the 2821 and 880's worked great with the outdoor antenna.
Is it because the 2821 and 880's are more of a commercial radio where the 2730 is more consumer oriented radio?
Flameout
6 answers to this question
