WRWH433
WRWH433's Achievements
  1. Thanks everyone!
  2. Ok. So, the repeater that has no tones set doesn't need a TX from me. The repeater that DOES doesn't need me to have an RX set. So by setting a TX tone and NOT setting an RX tone, I can use both when I am in range of either or. Correct?
  3. WRUU653 is correct. These 2 repeaters don't overlap, so I would essentially be using one in certain parts of my area, and the other in other parts of my area. I'd like to be able to have them both programmed on my radio, so I can hit one when i'm in range of it, and the other when i'm in range of it without having to make changes every time. Am I understanding KAF6045 correctly in that the one with no input or output tones would accept any tones, so I could program according to the one that DOES require input and output tones and still be able to use the one that doesn't because it's accepts any and all? That would be perfect if it's that simple.
  4. Quick question for you guys who have been doing this longer than me. There are 2 repeaters in my area on the same frequency. One of them has input and output tones, and the other one doesn't. I'd like to be able to use them both depending on where I am in the area. Can you generally set up two different repeater channels? One with the input/output tones, and one without? Thanks in advance!
