WRUP693
WRUP693's Achievements
  1. Thanks. The 2.06 version has the DIY columns with the correct frequencies.
  2. DIY Channel Cleanup Remove DIY channels with 467.52500 in the TX Freq column. GMRS repeaters do not transmit on this frequency. Modify the DIY channels with the mis-matched RX / TX pair by changing the RX value.
  3. Unfortunately, there isn't any 467.6000 value in any DIY channel. 3 repeaters in my county are 462.6000 / 467.6000. I can program 1 of them in RPT-3. Not a useful radio where I live.
  4. Recently purchased Radioddity GM-30 Firmware V06.03.009 Radioddity GM-30 GMRS Radio Program Software SAIN 3 LLC Version 1.05 The programming software allows modification to white cells. The gray cells are write protected. It is not possible to change ANY transmission frequency. Channels DIY-4, DIY-12 and DIY-20 have the correct receive / transmit values for 462.6250 / 467.6250 repeaters. Channels DIY-8, DIY-16 and DIY-24 have the correct receive / transmit values for 462.7250 / 467.7250 repeaters. All other DIY channels have incorrect transmit frequencies which cannot be modified with this programming software. The GM-30 cannot be programmed with Chirp.
