alex911
Everything posted by alex911
  1. thanks
  2. 1. when using chirp program: if the repeater has a tone: ex: 110.9) on the program, under column (tone mode) select tone and under tone column put the number and that provide me with in and out? 2. ex #2 if the repeater has a DTCS 205 I have to put it under DTCS code column and DTCS Rx code column and Cross Mode DTCS-DTCS or just in one column? thank you. using chrip program. WRUT292
  3. Thank will try to separate them. Thanks
  4. I can not make my two radios talk to each other via the Sebring FL repeater. both radios are close to each other. On the other hand I can tx & rx to everybody else via the repeater with both radios, but for some reason they cant talk to each other using the repeater. any Ideas???? Thanks
  5. What equipment I need to connect to GMRS net via thecomputer.
  6. DeoVindice: I am transmitting outside, set high power and I am using the antenna that came with the radio. I'm going to try the CSQ. let you know. If you can think in anything else?...Thanks
  7. I'm trying to program the repeaters near my home in my radio TYT8000E with the computer program, I only put ( mess around) with the RX/TX and DPL and leave everything else along, but I can not reach the repeaters. What I am doing wrong? no feed back from the repeaters ( I have like 8 around south FL). Nothing works? Please Help. If anyone from Broward or Dade Conty that want to be a mentor? Thank You WQYX519 email: a1solutions911@yahoo.com
  8. The Police department usually on a "trunk system", so nobody can listen to the entire conversation.
