mks
Everything posted by mks
  1. Awesome, that worked. Thanks so much!
  2. Nice. I'll check this out later today and let you know how it goes.
  3. A bit different than what I have... ic-f30gt-gs_f40gt-gs_manual.pdf
  4. Handy...depends. Don't have other cables.
  5. Yea those cables are pricey. That's why I stuck with the old one. Yes, using Icom CS F30G software, runs on W10.
  6. Cable came with radios when purchased some years ago from shop called GMRS Outlet as I recall. No longer around. Thanks! Mark WPVU464
  7. No worky. The Read Me on the driver install says that the program won't detect the HXA chipsets on W8 or above...I'm W10. I'm not using The Icom cable (OPC-966U), so maybe that would help? I just need to change some tones, so if it could be programmed manually that would suffice. Thanks. Mark WPVU464
  8. I dug in a bit last night and so know of the Prolific issues. Downloaded their file set and went through steps but so far that did not fix it, I'll take a look at your thread in detail and see what comes. Thanks. To be continued most likely...
  9. Any Icom folks that might know if these radios can be programmed manually? I have two of these that were programmed some years ago that I now need to make changes to (just changing some tones). I have the programming software and cable, but am having problems with serial port chipset / drivers (PL2303HXA driver, running on Win 10), so haven't been able to get it to work. User manual doesn't address manual programming. Thanks in advance if you can help, or have driver suggestions. Thanks! Mark WPVU464
