Everything posted by WRDU469
Short answer is I have selected a repeater channel with the least traffic in my area. I monitored and researched out channels that would be appropriate, then determined a tone that would not conflict with other repeaters. The open repeater in question is very low traffic and in the distance. There is another repeater near by on a different tone and it does not appear to be problem with ours if the radios are setup correctly. There is just no clean channel we can use due to the amount of repeaters in our area and changing channels for our entire CERT and fire district at this point would be challenging.
That is what I have noticed as well. I think all this gets me what I need to know about my repeater situation. Fortunately, the no tone repeater in my area is much weaker and 45 miles away. So it's not a problem for most my users, but some. I am just surprised anyone would setup a repeater with no tones in general.
This is all what I thought, thank you for confirming. The only real solution that I can see to ensure someone only hears the repeater with Tones they want, is to make sure their channel is set to T-Squelch instead of just Tone. That will allow filtering for just signals with a specific Tone.
Will an open repeater (Repeater with no tones) be triggered by a station on the same repeater channel but with programmed tones? I am trying to understand if two repeaters in the same area are using the same channel, but one requires tones and the other does not, will the open (NO Tone) repeater open squelch when it receives a signal from a station using a Tone and repeat that traffic.
WRDU469 replied to OffRoaderX's topic in Equipment Reviews
Btech also told me the CPS is not currently working on this new firmware version and they needed to update it. With the old firmware I could not get it work on Win11, but I could using Win10. After I updated the repeater, it would not work using Win10 anymore. I was told to wait for them to update it. So they know the CPS is broken. Fortunately, from what I can tell, I can do everything I need from the hand mic programming except name my channels. Other than that, the repeater works good. -
It's mostly the same. BTECH told me they fixed a bug with one of the settings in CW ID, but there is not inactivity timer or hours you can set. You just get ID by timer, unkeying or can just turn it off. -
Accessing a repeater with my Wouxon KG-935+
WRDU469 replied to WSHG703's question in Technical Discussion
Honestly, just add it as a new channel. Enter the frequency, make the offset "plus", and add the tone to CTCSS TX/RX. I personally like to use T-SQL for the Tone mode so I hear just that repeater on that channel. Program this through the CPS is easiest. Otherwise with the 935G+ you have, you can use the channel wizard. If you don't know how to use that, maybe search youtube for a tutorial. I am pretty sure I saw one at one point in time. And to see frequencies, you need to change the channel mode to CH+Freq in the settings. Again, easily done in the CPS. -
935G plus is my go to radio. I highly recommend it based on countless tests against Baofeng and TID Radios that I have done. They are a more expensive radio than most but I have not been disappointed by it's overall performance and capabilities. The other thing for me, is I have tested power output on many radios. The 935G+ has been the most consistent in "advertised" power output (close to 5 watts and in some cases more). Other radios in the Baofeng and TID radio department are hit or miss on output. For me that is the difference from making contact in a unique location I visit to not making a contact. That little bit of extra juice makes the difference for me against other radios I have tested from same location.
To be honest, there is a lot of good reasons to have an affordable back up radio like the H3. This is a back up for me or basically my wife to use in the event we get separated. The radio can be locked down and made easy enough for her to operate. I landed on the H3 based on many reviews and it outperformed most all of the budget radios in the power department when tested. I just cannot believe nobody highlighted the channel limitations in GMRS in any of the reviews I have watched. It still doesn't hit the advertised 5 watts but I will take 4 1/2 watts over a Baofeng 3 watt. That said, I couldn't justify spending money on another KG-935G Plus which is my main handheld. The bottom line is TID Radio should have better disclosed the limitations of this radio which hopefully they will acknowledge in a firmware update if they listen to my feedback. We will see.
Thank you! They didn't even respond to my email. Interesting they call a radio and "machine".
When I get time, I will give it a shot. I have all my programming saved, so it shouldn't be a problem to reload or import. Thanks for the information.
Just GMRS. I wouldn't be programming any HAM frequencies.
That was going to be my next question/test of the radio. Will the other channels transmit on GMRS frequencies if the radio is in normal mode. You have done this and it works?
It means any GMRS frequency programmed in to Channels 55 or higher will not transmit. Sounds like the DIY channels for GMRS are limited.
Well, I did see a lot of good reviews on YouTube. No where have I seen this limitation mentioned. I wish TIDRadio was more forthcoming of this.
Yeah that is dumb. I wish I knew this earlier. Thx
Does someone know what the GMRS transmit limitations are for this radio? I have the latest firmware and set to GMRS mode. I added my programming for several repeaters, etc. I noticed that I cannot transmit (only receive) on channels 55 and up. Ch 1-54 I can transmit on simplex or repeaters. Others see this issue or is this known? I could not find anything in the manual about this unless I totally missed it.
New Baofeng GM-15Pro Incorrect TX from the factory
WRDU469 replied to WRPG517's topic in General Discussion
I had all the same problems with this radio plus you cannot add simplex channels. Sent them back, gave Baofeng a bunch of feedback per their request, bought some TID H-3's and never looked back. -
For what it is worth, I use an Ed Fong antenna in my attic. Does very well. I was previously using a copper j-pole from KB9VBR Antenna's. Both work well and only a slight perceived difference in TX/RX range. I am getting a better SWR with the Ed Fong and continue to use that antenna. Here is a pic of that install.
I am looking at the same. I think we are going to land on the Btech RPT50. It should be relatively simple to use in case I am not around to program/fix/update, etc. It has everything we need onboard and just need to hook it up to an antenna. The limited reviews and information I have found so far look promising. This stuff does not need to be complicated and I think the Btech solution might be well worth it for a CERT and ECOMS organization.
Besides the BTech RPT50 repeater. Who else makes a GMRS repeater with built in duplexer, auto-ID, internal power supply and >40watt output? I am just looking at options to be the most inclusive and simple to use, but not have to buy multiple components to get it all functioning. Btech has the features I am looking for but want be sure I explore all options. Any other suggestions to research?
935G Plus: Silencing Area B After Scan Detects Signal
WRDU469 replied to CALO50's question in Technical Discussion
This sounds right from my experience. If scanning in SE mode, the scan stops on signal detection. If you have TDR on (allowing for duel display), then I believe you can duel receive as long as you have duel receive enabled. I only see the option to do this in the desktop software like RT Systems. The scan modes in the manual are not correct. I reported this back to "buy two way radios" but was just told they will tell Wouxun. If you scan in CO mode, when signal is detected, it stops, then resumes roughly 3 seconds after signal is lost. In TO mode when signal is detected, it stops and then scanning just resumes in a few seconds regardless of signal loss or not. In TO mode you have to carry out a function to prevent it from moving along in the scan such as hit Exit. Not sure if this was helpful or not. -
Sharing Channels Between Wouxun 935G Plus and 1000G Plus
Yes, you do need two versions of the software (one for each radio). But this is how I do it. The OEM cable does work with it. That is what I use. -
I should probably add that you cannot do this in the Wouxun software. I use RT Systems, but you can use CHIRP if looking for a free option.
