hartmans2587
hartmans2587's Achievements
  1. I'm not familiar with Chirp. Guess I'll have to learn about that. Thanks, Steve
  2. Yes, I understand it comes set for HAM freq range out of the box. I have set it for what Anytone refers to as Commercial use. That's what the OT software appears to be for. But the prog software still acts strange. Almost like you need a different software version to program once you set the radio for higher freqs in UHF & VHF. I suspect I'm missing something obvious but haven't figured it out yet. And no, didn't try resetting the freq ranges via the front panel. Didn't see how to do that yet but I'll investigate. Good thought. Again the OT software seemed to accomplish that. Thanks for your thoughts guys! Steve
  3. Been trying to program a Anytone AT-778UV radio with the programing software. Seems to communicate with the radio ok--reads & writes. However the software is acting strange in that it doesn't want to save a new file with new freq. data. Keeps showing up with radio's orig freq data. Thought I was goofy. I have selected the operating range I wanted using the SET software then using the AT-778UV prog. software ver 3.0.1. It seems to read & write from & to the radio no problem. Just select the correct comm port & that works. But won't actually program the new freq info that shows in the channel screens I create. Again, I've worked with LMR radio all my years & programmed many radios. Anyone else seen something like this?? Thanks, Steve
