Tpozek1991
1 Follower
Tpozek1991's Achievements
  1. So doing a Factory reset, going to GMRS only, and uploading the Radio to CHIIRP shows the normal channels. I then took a Suggestion from on here and went to channel 31 (Blank) And programmed my Freq, And Repeater name, tone direction, offset. saved to radio. Radio's freq and names are in the radio. But the Tone, Direction, and offsets are not.
  2. going to try that now. Thank you.
  3. CHIIP was used to change the names and offsets, and so forth. As they wouldn't allow me to change them inside the radio manually. All worked fine, until i turned it off to let it charge, and when it came back on my off set, and + - was removed. and unable to be added back. even after a Reset.
  4. Anyone Familiar With the TIDRADIO TD-H3 Radio's? Having a rough time getting everything setup. Used CHIIRP to program a few repeaters and change names into it. and it worked great, no problem. It then needed to be charged so i turned it off and plugged it up to charge it. When i turned it back on i noticed it wasn't hitting any repeaters anymore, but all the Channel names and frequencies was correct. so, i looked in the Offset and noticed it was back to default. Locked, couldn't change it. I then re flashed the CHIIRP list again, no go. everything from the offset to the Direction is also locked. So i factory reset it back to default, same issue. everything is locked and unable to change anything. In CHIIRP it's showing that it has the Offset's set and working. but the radio is not showing them on. I'm sure i did something wrong, but for the life of me i can't figure out What.
