WSDR451
Everything posted by WSDR451
  1. I figured out that I was trying to use the repeater on the DIY channels I created, but couldn't change the offset. I made the corrections on the repeater channels and...success!! Thank you everyone for your help!
  2. I have found the offset setting and have changed it to 05.000, however it will not let me save the setting. It says cancel and resets. Is this something I could fix if I used another CPS?
  3. WRXP381: I believe the radio is on high. I am about 10 miles from the repeater. The map shows a pretty significant radius and I am near the middle and I do have line of sight. I am currently using an Abbree tape measure antenna. WRKC935: I do have positive tail on this repeater, and others that I have programed. It repeats back with the name of the repeater and the time. WRYZ926: I'm not seeing a setting for duplex on the radio or the CPS. Would it be called Freq Hopping Code? WRUU653: I did not think of that. I will attempt that tomorrow with a distance of 4 miles tomorrow.
  4. Hello and thank you for reading! I am a brand new user. I am attempting to communicate on a repeater using a Baofeng GM15 Pro. I am using the Radiodity CPS. I have verification that the repeater is receiving me, but I feel I am doing something wrong. I have programmed a second radio to the repeater, however the second radio is not receiving my transmission. Repeater name: Central PA 600 out of Harrisburg PA Freq: 426.600 Input and Output: 123.0 Hz My steps: I created a DIY channel for the repeater on the Radiodity CPS. I entered the Freq correctly. I then entered the input under the RX QT/DQT and the output under the TX QT/DQT. I have not messed with any settings on the radio itself. I turn the radio to the repeater channel, verify the repeater, talk again with my callsign and a "radio check", and nothing. the other radio I programmed does not receive it either. I am BRAND NEW to this and I know that this is user error. Any thoughts or ideas?? Thank you from WSDR451!!!!
