WRYW480
WRYW480's Achievements
  1. It is a GMRS radio. and yes, all that is preset I the GMRS Channels and Frequencies. But what do you do if you want to remove “the automatic +5” from the transmit frequency?
  2. Good afternoon, Rev. Eric.  Could you please send me your email address?
    Thank you very much.
    Paul Ringel
    WRYW480
    pringel1@aol.com
    1. EricWRVY750
      EricWRVY750
      wrvy750@gmail.com
    2. WRYW480
      WRYW480
      Thank you very much.  I’ll get back to you after dinner.
      Paul
    3. WRYW480
      WRYW480
      RevEric,
      I am sorry I could not get back to you the other.  I will address my thoughts later in an email.
      Once again, thank you very much for your help.
      Paul
  3. BTW, you cannot use Chirp on a GM-15Pro. Baofeng's software, that can be downloaded for free; however, it only downloads a Windows based version. There is no Mac version available.
  4. I was under the impression that after you downloaded the software, you would click on the button that says send out to radio.
  5. Radioddity Software should work. Chirp does not work on the GM-15Pro.
  6. I’m not replying to this message but I have a question about access to a repeater listed by the Broadnet Repeater Group. I am a member. I have a Boafeng GR 15Pro. Here is my problem: I want to connect the Broadnet GRMS Repeater Systems at 462.625. When I log on to their listing on myGMRS.net I see: the frequency and then it says input and output tones unlisted. Also, I see the word Zello a lot when I am reading. So: when I turn my radio on, what do I set my Channel number to and then the frequency number. It says the offset number is +5 MHz. Can you tell me what should set the dial to: when I turn it on the top number says CH. 1 and the bottom number says DIY 1. Thank you very much.
