RadioSith
RadioSith's Achievements
  1. I am setting codes for repeater Dennis725 in Mass---it has Dpl codes, specific listed as dpl051. I have 051i and 051n options in my BAOFENG radio. Any ideas for which I should use? Thank you. wfse677
  2. Thanks...I did make request through this site... with the little blue button in the repeater info. 90% of the requests I made responded ... only the two I mentioned did not. There is no tone code listed for either and no luck on simplex. I guess my only option is to keep trying simples and also work through code list to see if I can guess it. Thanks to you and all those who chimed in. Cheers
  3. I am new to G-world and am programing my 3 radios. I have made a bunch of requests for entry/codes as aprt of my repeater setup. I have had really good luck on most of these requests, but have 2 outstanding for a few weeks which have remained unsnswered. Two questions.... 1) What is the general etiquette on this? The system doesn't allow any follow up until a decision is made, so not sure how to address these. and 2) I am in Eastern Mass and am really interested ingetting access to CMA 725 in Paxton and greg WSDQ286 in Norton...they are both very spacious in their coverage. Do any users have any inside info on these two assets and how to politely approach my problem. If it's just the way it goes that some you get in and some you don't, so be it, but doesn't hurt to ask. Thanks for the help. WSFE 677 Milton, MA
  4. Thank you for the info. Just got my midland hooked up to midland whip on roofrack mount.... lots of reception but no response on my transmit. The midland I have had dedicated repeater channels I use
  5. So I am super newbieto GMRS and not that technically inclined. I have been studying for my HAM license, but wanted to get GMRS radio (license) to get some experience. I bought the MXT275 because it was relatively plug and play, had decent power, and not too $$$$$. The big issue is I have a Bronco (very little if any flat horizontal metal) that rules out many of the traditional mounting locations and this reduces the type of antenna I can use. The stock mini, I put on the inside rim of the way back window (metal under plastic), but is inhibited by in the vehicle, low stature and week groun plane. I tried the Nagoya UT-72g mounted on Pizza pan on a plastic go box in the way back. Many of the same issues. I bought a window clip mount, but it is a SMA Female attachment for antenna, so have to use adapters. I used a 48" Abbree Tactical (only not driving), but this as wellas the other antennas recieve but do not transmit very well. I went to Quarry Hills in Quincy Mass this AM, huge rock hill, which has a perfect 360 line of site to the whole south shore, Mass area, but nada (there is a very tall microwave tower just to the north...which might be blocking signals. Now SWRs for the three are b/w 1 and 1.8 and nowhere around me, even this Quarry Hills did I get a single contact who recieved my call...or at least was willing to acknowledge it. As I said I am not technical so I am avoiding more complicated antenns instalations. I have checked the settings in my Midland, as well as The Baofeng UV 5G plus I have been trying also while in the car. Cant really test as homebc my town area is very wooded, lots of houses and I dont gave the resources, brain or body, to put up a mast or get on my house to put up an antenna. Basically stuck with Car options and jury-rigged pizza pans with a mag in my house...which by the way, is old 1938 NE with horsehair plaster over chicken wire...very Faraday-esque. I am stumped (doesn't take much).Can someone give me any tips on how to address my issues? Thanks in advance.
