I live in an apartment complex and just bought a TID Radio H8 but the shielding in my walls, not sure if it's steel or aluminum, prevents me from getting any signal out on any channel, even NOAA channels, unless I'm standing right by the window to my patio, Being I'm in an apartment, I can't drill any holes and any antenna I use must be non-permanent, I bought a mobile antenna with a magnetic mount (https://www.amazon.com/dp/B09TPZ221K?ref=ppx_yo2ov_dt_b_fed_asin_title) and although I haven't tried it yet, from what I read I need a ground plane of at least three inches around the antenna to get a decent signal, which I don't have. What I do have is a steel rail, about 1.5" in width and maybe eight feet long.
I have two questions:
1) Is that enough to get a good ground plane to use a 5W GMRS radio
2) if not, I found a steel pizza pan I don't use that is magnetic. It looks like it has some kind of coating, maybe teflon or some other non-stick surface but magnets do attach to it and is 14" in diameter. I know this is not optimal but would this work instead?
I saw there is a ground plane kit on Amazon but then I'd have to buy the antenna and then the coax. Money's tight, as everyone knows, so I'm looking for the easy way out here.
