Chunky1
Everything posted by Chunky1
  1. After ensuring comm port is selected and correct, the PC still can’t see the repeater.
  2. It does along with the power connector.
  3. The only difference is as stated, I am using the supplied USB/9pin serial port cable. I will need to get a different programming cable to connect to the power connection which was not supplied with the unit. I am only guessing there is a difference, not sure.
  4. Does the RT97S have to be powered up to use the programming software? I had read some where that this is not the case. I just received mine and wanted to create a base file before adding any CTCSS or other configurations to it. After downloading the software from Retevis I have tried with no success using the programming cable supplied with the unit which is USB to 9 pin serial port. It tells me to check my connections. Thanks in advance, WSCF376
