WSCW398
WSCW398's Achievements
  1. It is very possible that I am confused. funny thing is, it was set to high power by default. Although it was only transmitting on low power. I went in and changed the setting to low power saved it then changed the setting back to high power and saved it and now it is transmitting on high power. By the way, this is your repeater. I am located at 210 and Mountain Avenue. I am indoors using the long with antenna supplied with the radio. It is possible I am on the fringe of being able to transmit to your repeater. I am no longer getting a tail response from your repeater now. Not sure what’s going on. I am recovering from cancer and I can be a bit foggy on things, but I’ve checked things over several times and it seems to be set correctly. Also, thank you very much for responding.
  2. Yes, it is at the high power and I have tested with another radio that does monitor channel 17 and no voice comes through but the relayer tone at the end does. I tried programming the repeater on channel 17, but it won’t let me. This does not have a repeater channel 17 on this radio. That’s why I was using channel 25. channels 23 and up only transmit on low power apparently it may be FRS related. But those channels do have a plus symbol for direction of offset. I am new to this, but that seems to indicate to me that these channels are for repater use
  3. I have a Baofeng GM 21 handheld. When I try to program a repeater that uses 462.6000. I have to use channel 25 on this particular radio, and it will automatically do the offset but for some reason it will only transmit in low power. I have a repeater set up on this channel and when I key up, I do get a repeater tone after I let go, but it’s not transmitting my voice. I do have the correct transmit d tone set. question is is it supposed to only transfer in low power? And can that be the reason why my voice isn’t going through although I am hitting the repeater? thank you in advance! -Jim
  4. I have a Baofeng GM 21 handheld. When I try to program a repeater that uses 462.6000. I have to use channel 25 on this particular radio, and it will automatically do the offset but for some reason it will only transmit in low power. I have a repeater set up on this channel and when I key up, I do get a repeater tone after I let go, but it’s not transmitting my voice. I do have the correct transmit d tone set. question is is it supposed to only transfer in low power? And can that be the reason why my voice isn’t going through although I am hitting the repeater? thank you in advance! -Jim
