GROW
GROW's Achievements
  1. I'd mount it to the outside gable. And not to the roof itself. If you use guy lines, don't go through your roof.. guy it out to a solid gutter spike. And As long as you feel confident that it won't blow over , or be comprised if the power lines get knocked down, u should be good.. Mount a 3ft pvc pipe that's slightly wider in Dia. To your antenna pole.. directly into the gable.. then run your antenna pole through the pvc.. put an anchor pin/ bolt through both the pvc and your antenna pole, one near the top of the pvc and another bolt near the bottom.. 3ft is arbitrary.. if you use a 4 ft pvc then you could get maybe 3 anchors in.. 1 ft might not be adequate.. more than 4 might be too unstable
