WSHG974
Everything posted by WSHG974
  1. After you installed the software did you also install or update the driver for it ? Also the plug it seams like it in but if you look real close and see a gap at all its not in all the way. you will feel it kindasnap into place when it is in all the way. I had the same trouble when I first got the same radio and Im useing windows 10 the port will depend on what usb socket you plug into.
  2. I was wondering about the glass mount also for portable hand held Gmrs radioddity gm -30 plus if it would work better then the stock antenna ?
  3. Thank you so much for your help !!!!!! I ordered the programing cable will try it when it comes the repeater a pretty close to my location so I dont think that should be a problum I just dont know what menus to use for the inputs Im not the brightest crayon in the box yet Still learning and all the help I get is great ! Thank you to everyone
  4. Thank you so much for your help !!!!!!
  5. Thank you for your help I have been watching some but nothing about the plus also would you know about the same question for a Radioddity GM-30 PLUS ? I have both and end up the same results with both Im pretty sure its me not getting something set right,
  6. Thank you for your help I have been watching some but nothing about the plus also would you know about the same question for a Radioddity GM-30 PLUS ? I have both and end up the same results with both Im pretty sure its me not getting something set right,
  7. Im new to gmrs radio and have the Baofeng UV-5G PLUS and the manuel is pretty much useless. i want to set ip up to use a repeater in my area I have all the information and permission to use it as its a open repeater freq is 462.725mhz input tone dpl365 output tone 218.1 mz any help would be great ! Thanks in advance WSHG974
