NBTX
Everything posted by NBTX
  1. Ah ha!!! Problem solved! I had thought, incorrectly, that TA, aka Talk Around, is Kenwood's way of saying "no PL", or QT/DQT. I just checked my programming. I fat fingered the transmit frequency on one of the entries. TA is just Kenwood speak for "simplex". I feel a little dumb and humbled, but you learn something every day, right?
  2. Hello all, (I posted this to Radio Reference too, today. I'll also cross-post the solution for folks.) This has to be a common problem, as all four of my 840s exhibit this issue. I have a set of frequencies ("groups) set up in KPG-25D in two "systems". Software is working great in DosBox. (Need to donate to those guys!) See the attachments. Problem comes in after I push this config to the radios. The issue isn't in the KPG-25D software, that I can tell, since the config is fine, and it writes to the radios without any issues. The problem shows up when I'm flipping through the "groups" in the TK-840 itself. Once I get up to #12, the TA icon shows up. Everything above entry 11 turns into "Talk Around" and doesn't keep the QT/DQT settings. System 2 groups (aka, the second set of frequencies programmed into the interface) don't have any QT/DQT config in the radio...they're all TA. I looked in all the options and nothing seems obvious, like a "ignore QT/DQT decode and encode after entry 11", but maybe there's something else that is a little less obvious? I've also tried reducing the number of entries and changing the radio model to Sp, just to see. No differences in the radio behavior. Any help would be greatly appreciated. Chris
