WSHJ586
WSHJ586's Achievements
  1. Yes I know, replaced with a good antenna for those frequencies. Difficult in the Philippines as those are there license free frequencies. Can also use some frequencies on 70cm, no reciprocal agreement here on my amateur or gmrs license
  2. Sorry I haven’t gotten back, just checked output power on my Surecom and as I expected showing 0 watts, my 2 other H3’s indicating 5.5 watts and my H8 showing 9.8 watts. So just a bad radio I guess
  3. Yes I did do that with negative results
  4. Worked fine out of the box, after using Chirp had issue, after full reset same issue. I am licensed amateur and gmrs in U.S., however can only use 325mhz as I am in the Philippines until June.
  5. It transmit on low power about 500 feet same as high power.
  6. I own 2 Tid H3. On one radio it won’t transmit on high power. Have latest firmware and done factory reset with no such luck. Done multiple antenna replacements didn’t improve a thing. Check and resubmit power settings manually with nothing. Any suggestions or just a bad radio????
