BobDiamond
Everything posted by BobDiamond
  1. Thanks for your reply. Turns out the jumper cable has an intermittent short. And I bought that cable custom made to length using Times low loss cable from a company called ShowMeCables.com. So that will be returned to them. I located another jumper cable in my "junk box" of radio stuff and all is working perfectly now.
  2. I have a Wouxun KG1000G+ with power supply that I am using as a GMRS base station with a Comet vertical on the roof of my house. Transceiver connected direct to the antenna works perfectly. I just put a Daiwa CN-901V SWR/PWR meter in line and the meter is not showing any output power and it seems to be attenuating both the receive and transmit signal significantly. The meter is brand new, out of the box. I checked the obvious, radio to meter input, meter output to antenna, and 13.8VDC applied to the meter. But with the radio set to 50 watts output the Daiwa CN-901V shows nothing. What could be wrong aside from a defective brand-new meter?
  3. Thanks. You helped me. By asking about the other MENU settings related to TDR I went through the others and saw that somehow I had enabled the REPEATER-MODE.
  4. FIXED!!! I had MENU #54: RPT-MODE enabled to RPT-TX. I must have done that by accident as I was walking through all the menu options. I turned that to OFF and now everything is working properly. My mistake!!
  5. AUTOLOCK is OFF (Menu #47). I also cannot change between channel and frequency mode
  6. Radio is NOT locked. I can lock or unlock it with the D button as you said. All other Hot Buttons (A, B, C) give me a double beep. And the #8 on the mic for TDR also give me a double beep. I am in channel mode on the radio. Does that matter?
  7. The keypad on the mic is unlocked. The manual says to use the TDR function to toggle between single and dual display mode. The mic has #8 assigned to toggle TDR but all I get is a double beep. The manual also says by default TDR is assigned to Hotkey "C". But I get a double beep when I hit that button too.
  8. I am trying to switch between dual display and single display on my KG-1000G Plus. When I hit the TDR button on the mic (#8) all I get is a double beep. When I enter the TDR function in any of my channels I also just get a double beep. Also when I press the AREA button I get a double beep. I want to stay in single display mode and customize the text in the unused area. Somehow, when I was trying to do this the unused area now says RPT-TX all the time. The owners manual is not much help. Any help is appreciated. Thanks!
