WSIK943
WSIK943's Achievements
  1. Thanks for the info. I have tried all of the repeater channels and some I can hear. In two months I can't transmit/ radio check. I also went with the decode blank, no joy.
  2. CPS file. I don't get a thunk when I release the PTT.
  3. Just received chatter on R29, but no joy in transmitting. Will try the H-3 . Yes, it is on GMRS mode. Truly to get a picture from the CPS file.
  4. GMRS channel 20, config as above. Channel mode running a Ed Fong J-pole 35' in the air with 50' of LMR 400. HT is a Tidradio H-3 in GMRS channel mode. Program for DB20-G in channel 22 for a repeater that's 5 miles away is 467.7250 TX / 462.7250 RX with Encode input only.
  5. All, I can hit my HT but nothing else. All repeaters and some added. No simplex and they are 1/4 mile down the street.
  6. I'm all hooked up with [power and j-pole antenna. I can receive but can't transmit. With PTT button it shows red for transmit but now return on evan a simplex channel. Hope it might be a setting, could someone review??? T-CDC Off R-CDC Off RT-CDC Off Tone Dec Off Signal SQ W/N Wide RP Lock Off Channel Name Blank Comp Off NC Off 5 tone 1 2 tone 1 DSPSUB Freq Beep On TOT 3 Min DTMF 50 Ms SQL 2 Scan 5st Light 5 VOX Off VOX Delay zero TBST 1750 Hz #26 Display name Settings are from factory.
